I'm sure they were more than adequate for a pansi in a capri :)
Yes, they are great on 4 cyclinder light weight cars - that's why I recommended them. But pansy... them's fightin' words negro :(
further comments:
RE001s are probably a great tyre, but would be much more expensive yeah?
KU36s will probably wear pretty fast, since they are pretending to be a semi slick
I heard the KU36 last around 20000km so thats out of the question. RE001s are freaking exp. Got a friend that just got them for around 290 per tyre fitted + they use some fancy gas to make it lighter (nitrogen maybe?). RE050As are close to 400 each fitted.
Tas: I believe KU36 can be compared to Evos if not RSR. Very good reviews from users on the forum.
All these prices are for 215/45/17s.
Two track days on a GTR is my bet
I guy at the last track day had them on his track spec WRX. Could'nt stop cursing about what a rubbish tyre they were and how they should never have been sold to him as a semi slick. My humble pintara was quicker than him :)
He said they'd be going off for the next track day, so there you go, 1 track day on a WRX :(
1.3 tonne on 215s :S Dayum. my SS have got close to 20k kms on them now and no sign of wear. I think I'm losing my mind though because everytime I look at the car I swear there is more neg camber on the front. Paranoia because I did all the camber arms myself keep thinking I've f**ked something up lol.
Yes, they are great on 4 cyclinder light weight cars - that's why I recommended them. But pansy... them's fightin' words negro :)
Fair call, they're probably more than adequate for the VW too.
But you're still a pansy :(
Damn i'd be happy with 20k out of ANY tire. I'd expect more like 10 out of KU36s
I think the Evos compare to the KU31 actually and the RSR compares to KU36.
Both RSR and KU36 are soft road tyres being called semi slicks by dodgy marketing departments
FYI: $550 fitted ea for 4x Toyo R888's 18/225
how much for 18/265 :)
My pintara ways sh*tloads more than that and it was rocking 215s for ages
True shit. 215s just seem like such a tiny tyre lol. I spose its no worse than the 2.5 tonne falcodores with their 235/245 ling longs on em.
Where from? what about 215/45 and 235/40 in 17?
Place out on the bay. I reckon if we all went there to buy the toyo's we wanted, they'd do us a deal dispite being different size's
Not very light if you asked me. The spec sheet says close to 1.3tonne... only 200kg light than mine.
they must be heavier now - last i saw they were 1130, which is 100 more than the capri.
but still - i usually think in terms of a falcon being 1.7 tonnes... i consider that to be a heavy car (without getting into utes and crap) so 400k less is a pretty big difference... but either way
it sells tyres bitch lol. But yeah I wouldn't put rsrs or ku36s on a beetle. overkill.
I think you must be stupid to do that. I cant justify the wearing on such a car. I want something that'll last for 40000km!
The stock tyres are 195/55/16 if you're interested in knowing. Its around 1250kg to make it even more accurate.
The threads on mine still look good after around 5000km. Hopefully it'll last me another 20000km... hahaha.
    • Well, yes, every CU on the bus is available via the Consult port, but whether the scanner you are using is capable of talking to the TCU, the ABS/TCS modules, etc etc, is what is at question here. Many of them are only for engine codes. So, if you have one of those, you won't know if the ABS is having a bitch.
    • That's now. R chassis Skylines come from a time when the tolerance in the ADRs was a bit more....slack. My car, on 235/35-17, which is damn near the exact same size as the original 205/55-16, is pretty much bang on correct indicated speed across the whole legal range. That's demonstrated with constant speed run over 5km, and GPS speed. It's just the luck of the draw. My particular speedo head has to be the thing that is "calibrated" that way, because everything else (the diff ratio, the gearbox and the speedo drive**) are all same same as most other Skylines. **OK, so the speedo drive is a Navara unit to drive the R32's cable, not the electronic unit than an R33/4 would normally have with teh same gear on it. Otherwise, I applaud your OCD tendencies, and I would do the same if I needed to.
    • Not too sure, I believe the Nissan consult port does everything? Also just filled up the reservoir to full and the light is still on. The float seems to move up and down fine.
    • The speedo's can be very conservative, when my Mazda NC MX5 speedo is showing 118kph, the GPS, and a calibrated radar.... cop mate.....hits me at around 110kph +/- 1 or 2 kph, and that is on a 215/45 17, stock tyres size is 205/45 17 as well, so weirdly conservative with stock tyre size When my Commodore speedo red 116kph GPS had me at 110kph on 255/40 17, so again conservative Google says manufacturers need to set the speedo from 4 to 10% slower than actual road speed.....for safety.....and compliance  After doing some offset and clearance measurements to see what can fit the NC on 17x8 +40, without guard rolling or rubbing anything at my current ride height, I've decided that when my tyres are toast, I'm going to fit 225/45 17 and see where that gets me IRT actual speed of my speedo and GPS/radar From the online calculator I should be still be doing around 5kph under an actual 110kph when the speedo is showing 110kph My ADHD requires that when I'm doing 110kph on the speedo, that the actual road speed is actually really close to that, and not alot slower And going from 205 to 225 still keeps the car within the %/mm allowable in the NSW vehicle rules and regulations, which is nice, as long as I'm looking at the latest version that is.....LOL https://www.nsw.gov.au/sites/default/files/2021-02/RMS-13.464-Light-vehicle-modifications-Vehicle-Standards-Information-No-6-November-2013.pdf
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
