I'm sure they were more than adequate for a pansi in a capri :)
Yes, they are great on 4 cyclinder light weight cars - that's why I recommended them. But pansy... them's fightin' words negro :(
further comments:
RE001s are probably a great tyre, but would be much more expensive yeah?
KU36s will probably wear pretty fast, since they are pretending to be a semi slick
I heard the KU36 last around 20000km so thats out of the question. RE001s are freaking exp. Got a friend that just got them for around 290 per tyre fitted + they use some fancy gas to make it lighter (nitrogen maybe?). RE050As are close to 400 each fitted.
Tas: I believe KU36 can be compared to Evos if not RSR. Very good reviews from users on the forum.
All these prices are for 215/45/17s.
Two track days on a GTR is my bet
I guy at the last track day had them on his track spec WRX. Could'nt stop cursing about what a rubbish tyre they were and how they should never have been sold to him as a semi slick. My humble pintara was quicker than him :)
He said they'd be going off for the next track day, so there you go, 1 track day on a WRX :(
1.3 tonne on 215s :S Dayum. my SS have got close to 20k kms on them now and no sign of wear. I think I'm losing my mind though because everytime I look at the car I swear there is more neg camber on the front. Paranoia because I did all the camber arms myself keep thinking I've f**ked something up lol.
Yes, they are great on 4 cyclinder light weight cars - that's why I recommended them. But pansy... them's fightin' words negro :)
Fair call, they're probably more than adequate for the VW too.
But you're still a pansy :(
Damn i'd be happy with 20k out of ANY tire. I'd expect more like 10 out of KU36s
I think the Evos compare to the KU31 actually and the RSR compares to KU36.
Both RSR and KU36 are soft road tyres being called semi slicks by dodgy marketing departments
FYI: $550 fitted ea for 4x Toyo R888's 18/225
how much for 18/265 :)
My pintara ways sh*tloads more than that and it was rocking 215s for ages
True shit. 215s just seem like such a tiny tyre lol. I spose its no worse than the 2.5 tonne falcodores with their 235/245 ling longs on em.
Where from? what about 215/45 and 235/40 in 17?
Place out on the bay. I reckon if we all went there to buy the toyo's we wanted, they'd do us a deal dispite being different size's
Not very light if you asked me. The spec sheet says close to 1.3tonne... only 200kg light than mine.
they must be heavier now - last i saw they were 1130, which is 100 more than the capri.
but still - i usually think in terms of a falcon being 1.7 tonnes... i consider that to be a heavy car (without getting into utes and crap) so 400k less is a pretty big difference... but either way
it sells tyres bitch lol. But yeah I wouldn't put rsrs or ku36s on a beetle. overkill.
I think you must be stupid to do that. I cant justify the wearing on such a car. I want something that'll last for 40000km!
The stock tyres are 195/55/16 if you're interested in knowing. Its around 1250kg to make it even more accurate.
The threads on mine still look good after around 5000km. Hopefully it'll last me another 20000km... hahaha.
    • Why are people so insistent on making dirty water?!
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
