lol when I got my r33 it had nankangs on it. Shit in the dry, deadly in the wet lol.
Josh - Will be a while before I'm putting anything close to the triple 8s on my car.
arent 888s as noisy as shit??? I went in a car that had them at a track day and the buzzed, screw that for a car i drive daily
I had RS's on my r32 and they lasted me a year (half of which i was driving 1000km a week), were not overly noisy but they were capablably of giving you a scare if they were not yet warmed up
daves seats look sexy. Go to group buy section n find the thread. Wouldn't mind some for the 31 but can justify paying that much for a seat when I barely paid that for the car!
At 200kph...
Like cum on a blanket in the wet too..
Arent 888s proper semis? If so I would expect them to be real noisy.
Josh i admire your dedication to grip because i would go mental....because at wakefield there is nowhere you are going anywhere near 200 and it was annoyingly loud through a helmet!
I'm a boy who likes to stick to things :) hhaha
Yeh they like to "hummm" a bit on the road.. My god 400rwhp/rb26/gtst pissing down with rain up nebo.. Yeh, just yeh. Very impressed.
awwwwww.... the seats are sprints :) I was hoping they'd be r100s or speed 2s
the speed 2 is the update version of the speed which is a update of the sprint v. i cant find the speed's in australia.
ive sat in a sprint v and its very close to the bride zeta. and for half the price you cant go wrong, and the material feels stronger.
if you want i could en-quire about them for you?
Edited by 32_Dave
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
