Re: Bob Jane - Valley - Rant
Bunch of ignorant f**ks. I work in New Farm so thought, why not I'll pop down and see what they can do. Walk in asking about semis, clown can’t get them, rings around and quotes way above everyone else (fair enough, guess he thought he could pick up a few bucks).. THEN!! Try's to tell me you cannot fit any 225 tire on 10.5+ inches, I kindly show him my car out the front with 10.5+ with 225's..
Tried to up sell some all rounder POS tire as a sports tire for $480each, with the argument of "some guy with a commodore swears by them". Told me I'll have to buy tubes off him so he can "expand" the tire on the rim and all sorts of voodoo magic tricks.
Apparently he used to "tek-screw" drag slicks onto his "drag cars" and he is old school and knows a thing or two.
f**k you Bob Jane Fortitude Valley and to the guy who has the POS white S13 that works there your car is shit
@ nismoh - unfortunately ive heard bad shit from those guys too (i used to work at dominos new farm, and when i was looking for tyres i was told never go to them)
ugh f**king mustangs
im so pissed katie's 32 got pinched
We should jerk on there door
lol i think emo hair styles make u gay..
luckily i dont have one.. :P
i just did a clutch change a on burnt out R33.. the smell was so bad even the interior smelt like it.. ffuu :P
    • Sorry I didn’t explain myself properly, by free revving I meant if I just floor it, it gets to 7kish and will start to break up/not hit limiter properly, off boost I’ve driven the car until near on empty. I have a fuel pressure gauge mounted in the engine bay, holds fuel pressure consistently full tank or half tank even when revving, and no the pump sound doesn't change. all the fuel lines inside the tank are fairly new but will look into it, could that also be an issue with the lines outside the tank ?
    • Yeah maybe I got a bad batch that only lasted 6 years. Or conversely maybe I got a good batch that managed to last 6 years.    Either way I have sourced a set of OEM hub/bearing assemblies  so I keep hearing! Even from life long mechanics. Apparently this failure is unheard of…
    • I am trying to understand how that even happened to the hub... wtf
    • Hell, I'm sufficiently wary of the ZSS suspension arms, let alone something like a hub.
    • Got it back home and got started pulling the hub off and diagnose the issue. Axle was stuck after removing the 36mm nut so i used a 3 jaw puller to try and push it out and... eH5FXvJ8.mp4   spend the next few hours trying to remove the axle from the remaining hub as it was very much jammed in there when the spindle sheared off. resulting damage as below R53AIy6 - Imgur.mp4   Looks like the was already a stress fracturing in the spindle as can be seen with the darker cracked section My working theory is maybe when the pinion gear exploded last year the shock put through the hub was the initial crack. Then a few events later it finally let go. Just lucky it happened where it did and not 190km/h on the next sweeper or into the hairpin The bearing/hub assembly went in in 2019 and were non-genuine "ZSS" assemblies and no nails were harmed in the process. #BreakHubsNotNails
