okay noobs.
Electrical is far better then a mechanical boost gauge. And no electrical doesn't mean that the gauge lights up its to do with the sender. defari if you go with tristans sugestion and order a autogauge electronic boost gauge you'll be more than happy and we should be able to work you out a good price 10% discount on rrp.
the gauge im referring you to is:
http://justjap.com/store/product.php?produ...=400&page=1
270 stepper motor = type of motor, with 270 degrees motion
peak recall = this recalls the max boost you hit during a drive, great for tuning you t-piece.
bang for buck you cannot go wrong, but if you have loads of cash by all means get defi's.
What can you do? Want to do? Dont care?
At the moment not really fussed hey. What I WANT to do, is pannel beating/spray painting. What I can do is a great range of things because I've done a bit of everything over the years. I just want the dollars rollin' in yo :):happy:
broad minded persons!
have to come to my shop today to have a beer with me!
pffft, as if drink that women's nectar :down:
Mechanical ftw
uhhhh... you might be thinking about analogue vs digital, brah :)
huh?
kevin you're killing me, electronic owns
+1
electronic ALWAYS better than mechanical (y)
+1
Rather do some research about the companies that make it if u want a more spot on accurate gauge..
Defi aka Nippon seki has been in the watch industry alot longer and thus more accurate guage
if u want cheap shit that looks like defis but not the real deal... more wiring and more hassle.. be like 32 dave and buy autogauge..
if u want less wiring, easier plug and play more accurate reading then defi is the way to go..
everyone will have their own thoughts..
yes defi are the shit,
and after them apexi and blitz are the best option
but for our application and bang for buck - autogauge is sweet
i mean just looking on nengun now - a defi boost gauge is $225, and that doesnt include the controller, whereas the autogauge is just under $100
it depends on your budget, what you want out of your car, and where you want to take it
autogauge has been in the game for a long time. and there not cheap shit. when you say more wiring and more hassle, doesn't sound like you'v had much to do with this series of gauge, they make shit very easy, it'd be less wiring then the defi's considering they need that control box. autogauge consist of getting power to 1 gauge and then it loops in and out through plug in wiring harness, then all you need is the sensor and the wire going to the sensor, i don't see how that's more hassle ???
sweet, i was gonna go and get one of those crappy sabre ones from autobarn for like 80 bucks, but yeah if you guys recommend the auto gauge ill go with that..
not looking to go big hp car, keeping it stock but just wanting to know what boost its running as it has a manual controller, not sure what its boosting at the moment..
Thats nengun's prices.. have u even bothered to look else where??
if ur not willing the spend the money.. then go buy some sabers.. cheap pos like autometer..
LOL
GL for accuracy too
Blitz and apexi guages are just like omori guages.. good but not that great..just wiring slapped togehter and sealed with braneded logo..
prob 10-12psi would sit nice, depends do u want an excuse for a new turb? Its just trial and error with the t-pieces, start low and wind you way up and use the gauge to tell you were u sit.
What are u two doing.. blowing eachother while sitting next to each other??..
sure autogauge been in the market for a while.. but its just like saying.. yea.. power and spirit products been in the market a long time too..
a control box?
one wire goes into that? and control box goes to a power source?
sounds like u havnt touch that either..
You do realise Autometer and Autogauge are owned and made by the same people in the US "Autometer" Just happens to have a huge range of gauges no matter your budget.
Have you even looked at their style of guages?
its just like Drift style gauges..
i think your better off going to patch up your shell mate if u want to talk products with me :happy:
    • I tried the next one up from 600k ohms which is 60M on my multimeter and all readings came out as 0.00 ohms so right now the most accurate is 600k ohms with only a 0.1 ohms difference between coils. Three coils read 1.4 ohms and the other three read 1.5 ohms.
    • surely that is a control arm, not a sway bar. In any case, visual condition should not be an issue, excessive movement under load (eg with a big pry bar) would be the issue. I can't see 99.999% of pink slip places even looking, let alone trying to test it
    • I attached the image of the only thing I found, nothing to do with ohms in the manual only torque values etc. However, being they are so close to each other I am almost certain they are good. Tomorrow I will test the spark plugs while I am there. and look at the ECU connections.
    • Hi Gents. Do u know what 18rim will fit under R32 GTST with no modification of current setup I have. I have buddy Club P1 17x8 on front and 17x9 rears and they fit well.   Will an 18x9 on 35 off set with 235 tyres up front fit? ON the Rears i can run the rim size n fit 255 or 245? or i got option to get 18x9.5 on 35+ Offset n 265?   CHeers
    • And, when measuring and getting <2 ohms, perhaps chose the next larger range than that, rather than something with a k in it!
