^^^ yes, unless one is in-line or behind the actual dash speedo.
and tas, yes i do deal with lights and fittings on a day to day basis, mainly cheaper fittings, cause majority of people cannot justify spending big $$$ on light fittings, could also say the same about gauges.
ah very interesting :happy:
hmm, i wouldnt mind a single pillar mount for the 180 - keep it tidier than how it was in the 32
sweet! i'll bring a blank next thursday.
I just checked the front of my bike this arvo. need to rebuild the front forks. $65 for the parts to my door from England. Might have to make a big bike part order soon. Needs disc brakes
anyone want to finance a RB30DET build for me? in return i will build you a RB30DET also, but your paying for both
what are the forks man?
if there dirtjumpers there not even worth $65 buy some new ones lol look on rotorburn.com (farkin)
im checking out that SGS soon, its medium tho, so dunno if its to big.
ps: group buy is going f**king awesome.
and considering a universal rail group buy if anyone is keen?
Edited by 32_Dave
Clown who used a stolen credit card to buy my bike (about $6k worth) posts on roto burn.. lol at him and the Police warrant..
what bike did u have josh.
happy bday mr. tasman :P
I was lucky enough to get a brand new specialized they built for team members only with carbon goodies out of the states. Twas fun. Miss riding.
get a bike again !!! then ride with dan / me ? haha if this sgs is to big you should buy it cause your abit taller. :P
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
    • This. The R34 handbrake icon DOES come up when the brake fluid level is low. You might be sitting right on that threshhold. I have been down this diagnosis path and this was the solution (and it was pretty much as full as your picture is to begin with).
