as much as i hate watching that proactive and miricle blade shit...i'll still sit there and watch it, not like there's anything else to watch. What ever happened to all the calling in guessing words games. Just realised they were all gone. Probably for the best.
The word games were on earlier than the infomercials!
They were usually hosted by some loser from big brother or something equally as horrible and displayed just how stupid the population of this country can be. So I'm glad they're gone!
and every day is a good day for a day off :banana:
Yeah that's right. I remember why i hated them now. But yes, i just wanted a taste of your good life john. Tried to sleep in but body clock wont let me.
Maybe its time we organize for a dinner at southside!
On a side note, isnt this the 33gtr driven by a chinese guy that rocked up the at the car wash?
http://www.skylinesaustralia.com/forums/95...le-t293695.html
Just checked it and it is! That was a quick disposal.
Wheres those photos Michael? Check the plates!
sth side dinner sounds good. with or without cars? (piss up?)
just checked the pics and yes, that is the one we saw few weeks ago at the wash. what was wrong with it tas? or was it the black one...i forget.
Yea sounds good. Little Singapore??? Hahaha. Or maybe just go to Tas' favourite place, the old "Shiok". I'm sure John (southside John) would be up for it.
Both have something wrong with them... Hahaha. Black one's got some weird sound from gearbox, clutch or something. Silver turbo sounds like its dying. I remembered he mentioned got that gtr for 17k...
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
