silver one sounded rough as guts. Wouldn't touch it with a 10 ft pole. Although if you got it for 15k and put some money into it you would have a pretty cheap 33 gtr.
Bah Saturday night was shit. Lost $250 to bad luck carnts! puts back the 31s progress a couple of weeks at least. Liverpool won on the weekend though so :banana::D:D
Oh and all my uni assignments are doneskies! Now just got to learn everything for my final exams hurrah.
If you can get it down below 15k, it might be worth it for someone thats gonna do up a full track car. After selling the bits in the car that you dont need, it will definitely be worthwhile. But at 19k... I dont think anyone that knows a bit or 2 would touch it, not even me when I dont know shit 1yr ago. Hahaha. At least I know if those 2 turbo goes, you'll be looking at 3-4k to replace them with labour included.
It's parts vaule would have to be 15k.
Which brings me to my next question; lol at people offering less than what a car is worth in parts.
People like me will only part out cars, thus bringing the over supply down and price stable.
Only works that way if people want to waste 6 months trying to part out a car. The majority of the parts value would be in the engine anyway and its definitely on its last legs. For every 1 person thats willing to sell there car as parts there are 10 more willing to sell it for less as a package.
Only those who borrowed to high hell.
I've noticed, with Gtst's at least there has been a turn, if they cant sell them they will just keep them. Which is fair enough.
Either way you wont make any money out of parting a car. Its only a matter of time before they're all as cheap as 31s lol.
You might be suprised.
Lights, trim, little tid-bits etc. All bring good money as the cars get older.
Noel is a prime example of making very good money out of parting out perfectly good cars.
the last car Noel parted out he managed to get for 4k and didnt make a massive profit or anything...and he still has bits of it sitting around!
But yeah the price he got it for was hardly typical!
Yeh and with that car, what if he tried to sell the shit on all the sites.
sd
pf
boost
ns
ect
Put half an effort in.
My point is, you're all a bunch of tight kents and want everything for nothing. Nothing shits me more then some smart ass trying to offer less than what the car is worth for parts.
I enjoy nothing more then closing the garage door in people's face's saying I have no desire to sell my shit to you anymore.
I didn't think he made that much out of it?
sd
pf
boost
ns
ect
Depends on how much you value your time I spose. I wouldn't be arsed parting out a car for an extra 2k when I can just sell it for less and be done with it.
Because I think $5k R33's and R32's are too cheap and if someone wants what I have I will sell it for what I think it's worth. Every single car I have owned except the Lexus and quick R32 I got more then what they are worth... I dont plan on changing that
If that means stripping the kent right down, I will.
I'm a bit of a shit of a person to buy from, not wasting my time comming to my house to get a closed door in the face :(
can i like be at your house one time when you do that - i rkn itd be freaking hilarious
Sure. I have nothing for sale atm though. Other than parts, which arent of vaule to me tbh.
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
