tis going well. Needs another wash, cant keep the bitch clean. I'm going to order one of those just jap oil coolers. 19 row or 25 row? Will I have any problems with space with a 25 row one?
You'll have trouble with a 25 row but they can still be made to fit on the passenger side. Usually a 19row is fine if you aren't going to be dedicating the car to track events only.
Putting the 25 row over on the passenger side sometimes requires some custom braided lines to be made which adds cost to the kit price.
sweet ill go with the 19 row one then. Should be fine for what it gets used for now. It might see a few track days in the near future is funds allow it :P Rebuild here we come hurrah :thumbsup:
oh and ridiculously pissed. Lost some money at the casino on the weekend and it appears my quick n dirty table math was a little off. Some dumb american bitch hit runner runner straight on me. I figured it out at the table to be about 19 - 1 against but its actually around 68 - 1. Gay shit lol.
You might get me on the straights but I'd have you in the corners. Many underestimate the mighty Hatch-Ute's potential.
Speaking of corners, you need to contact Noel. He mentioned yesterday that he needed to get in contact with Gonzo and you might know how.
Ill see Gonzo on Monday if that helps...what does he need ?
and Molly Quinn is hotter than hot boyo. Martin knows the score :thumbsup::P
Damn Straight!
apart from the whole 16 year old business i'll wait another year.
You have much to learn, my young apprentice
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
    • For me there is a massive difference in manufacturer or big brand crippled android (Sony, Kenwood etc) vs the sort of thing I've installed here, which is basically just a tablet in DIN form factor with open Android, and the other model of course is mirroring - Android Auto/Carplay. I hate the locked down manufacturer and AA options where they decide what apps I'm allowed to install, including the Launcher but also importantly things like Ecutek (for this car) or Real Dash (Stagea) are not supported. Plus those crippled versions tend to be slower due to both overheads and lower spec hardware. On the other hand, when this breaks I'll likely be in trouble for support....but how is that different to owning an Infiniti anyway
