You are easily pleased then. f**ked if I'd pay over $1000 for a second hand POS clutch that may or may not explode at any time.
Can build and sell retail the EXACT same thing for half the price using all new parts.
Astro:
And 3 puk? WTF were you thinking? I hope you don't care about ya neck
explain sir?
hmmmm... looks like I've missed nothing so far...
*scampers back into the shadows**
hahah its a bit like that for me today
Careful tristan The Jewish are after you!
huh jews?
i cant think of a jew without thinking about borat hahah
politically incorrect, but hilarious
explain sir?
Have you ever driven on a 3 puk button clutch before?
What is the car being used for? And how much power does it make/will it be making?
Racist much?
hand over the jew gold, kyle
Side note : Did i tell you's that if i can get enough donations I will be growing a hitler still moustache for movember... but I might call it a chaplin... not sure the jury is out on that one.
nope i havnt, car should be making around 220kw-ish + if everything goes sweet, used as a dori machine
Then a 3puk clutch is a poor choice. Whoever advised you on this needs educating.
You may end up liking it but it is EXTREMELY harsh on driveline stuff. Say goodbye do diff, gearbox and universal joints. You'll jolt your neck every time you take off but it'll kick nicely for drifting. But then again, so will a 5 or 6 puk button clutch but it won't be as hard on everything.
3 puk should be good to hold 350+rwkw, 6puk at 300rwkw and 5puk at 350rwkw.
So basically the wrong clutch for the job
Plus when the clutch wears out you will need a new flywheel. Because from all the clutch riding you are going to be doing while you drive it on the street, it will machine a large deep groove in the flywheel.
*plays dramatic music while waiting for Elite Racing's reply"
I've got 5 minutes spare if you want some lessons. Hmm, on second thought, might need a decade.
I was happy.. Knowing what happened with Noel and knowing what really goes on after reading about parts, not so happy. I was a lucky one. Back in 02/03 when the clutch was bought there wasnt really a huge aray to pick from.. Started with an OS twin plate, shagged it. JB worked, heh.
Not easily pleased, you know this.
you raise a very good point, i didnt take into account my drive line ;)
oh dear :(
I just assumed from the car you drive.
Oops did I say that out loud
Im pleased that car runs. Im a slave to offset. It's in keeping with mud crabs and so forth I guess.
That car now is in better mech nic then half the shit boxes on car sales :(
oh dear :(
And just to clear up what I believe Taz is getting at:
I don't give two flying rats arses who sells you a clutch, installs your clutch or whatever....I am here for advice only, not to pick up work.
I fit around 30 or so clutches a year to Skylines and silvias and have done for the last 6 years. Just telling you how it is.
All my cars have had button clutches fitted so I know what it's like to drive them. I have sold and fitted many to others and can tell you it's hard enough satisfying people with a 6puk clutch (which is AT LEAST twice as easy to drive than a 3puk) when they have never driven on them before. There is only two reasons for needing to go button in the first place.
1: The car makes more than 300rwkw
2: Drifting
Why can I never get a bite out of you? You wanna have sex with me don't you?
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
