Side note : Did i tell you's that if i can get enough donations I will be growing a hitler still moustache for movember... but I might call it a chaplin... not sure the jury is out on that one.
Hmmm, I think a chaplin moustache is a little bigger than a hitler one. I'm willing to donate if you do an actual hitler one, and rock it to a meet. You can call it whatever you like, but you'd damn well better look like hitler :(
Done hitlering it up. . I'll get the donation forms etc ;)
I was rebuilding engines and gearboxes in my first year, the good part of being an apprentice in a small workshop. Yep clutches is actually taught in the second year tafe module. So yer they do teach that in as a 2nd year apprentice.
From my veiw, exedy is ok for an off the shelf application, i got one in mine thats lasted 3 years so far, i wasn't too happy with its clamping force so i had that beefed up by jim berry, its got a really nice feel to it now, not a weak stock feel. But i have driven smity42's clutch that jim made and its a great clutch doesn't slip and feels really nice on the pickup.
Also a jim berry clutch will last about 2 times longer in a ferrari than the standard one will.
My next clutch will probably be an OS or something like that.
Exedy do make a nice lightweight flywheel though
Yep all tax deductible. Signed up on the website and everything. Should have put the mo to a poll and seen which one would have been the coolest. We could change that ? Or still keen on the "hitler" ?
There was a pole ? Man why wasn't I informed ? Sheesh..
Sorry haha next time i will be sure to inform you :(
Excellent. Always like a good pole...action...
So wrong ;);)
    • 21 is explicitly the coils detected as the issue. Is it guaranteed the actual issue? No. Just the ECU thinks it is. When you say rattling, describe it better, get an audio clip as best you can if possible.
    • Yea got me coppers. Bad news is I just put them in and the car still has the light and shakes. I also noticed I hear like rattling coming from the exhaust piping right under me. Does 21 also have a possibility of being O2 sensors?   So, coil packs are good, the harness is good, the MAF is working, and obviously the spark plugs just replaced and working.
    • Make sure you drop the GTT base tune back in, and set your injectors again, this will remove anything playing up with it you may have removed. Possibly lean there as it's normally a fast transient going THROUGH atmospheric pressure, and a turbo motor would then quickly go richer as boost builds. The only worry you MIGHT have is ignition timing, as the DE is higher compression than the DET from memory. But again, you're not in boost, so the DE motor will be a lot more forgiving at atmospheric.   Get Murray, Kinkstahs, and Johnny's input on tuning haltechs, those guys have played with tuning enough in the past to be able to help now you're past the trouble shooting stage of the MAP issue
    • @Rusty NutshI mate. Do you have a pinout diagram for the na neo auto ecu?
    • Yeah thats the plan now. 🤞
