Have a yarn with zenon Josh, Thats about where he's at with some carefully thought out spenshun mods and he has a ball in that flat capper of his.
Yeh might hit him up. My teins gotta go! no question there. Dont even think they are worth trying to save with less silly spring rates in them
T51Z on a stock rb20, and then change the timing belt.
and then fit a new intercooler.
then some more parts.
then wait a couple weeks
RB24 is a waste of time.
Plenty can be done with the RB20. Need to spend a bit on cylinder head work though if you want the numbers and torque.
Leave the bottom end for now, take off the head and put on a pre-ported one with bigger valves etc. Go Pon cams, Angry German with surge tank injectors and a NISTUNE or I have an ECU in my 20 which has already been chipped and I won't be needing it. Already set up for 550's and a Z32AFM
I can't use AFM with the new setup as there is nothing big enough for 1rwkhp
So all you'd need would be injectors, fuel system, JJ intercooler and a couple of other bits and pieces. Could easily get 220rwkw on that turbo.
Then when you can afford more of an upgrade (or even want one) do the cylinder head and go bigger turbo/cams. You can make 235rwkw on the stock cams with stock/untouched head.
You can also do 205-210 rwkw on stock injectors and AFM too but I would be careful running them at those levels.
Is it worth toying with cam gears? Or not worth it unless I went to a full ECU?
Worth my time buying a 6boost manifold for the current turbo? (I have no views of going high mount/ex gates).
The key is, response, keeping it alive and staying consistent
No, stay factory manifold but maybe heat coat inside and out.
easy to keep it alive but revs will have to be cut short at 8k until you can afford/want bottom end work. And I'm not talking about beat kind of bottom end work.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
