As long as its good beer, or bundy and coke :D . Wasn't your kill switch(s) going to be an epic project?
Yeah, but I was thinking might be a good idea to do a basic one for now, and then change things down the line.
limp bizkit = worst and you two will burn in hell for quoting it
+1
lies!
everyone was into limp bizkit at some point in their life
this post was backwards... it should say:
LIES!
Edited by Isola
queers
Another quality, meaningful, and thought-provoking post there from Tasman. This thread would go nowhere without your input :D
anyone know if mechanics can easily take lock nuts off rims? (previous owner lost theirs) now I cant take the f**king rims off.
Any mechanic worth his salt should be able to, failing that take it to a wheel and tyre shop. Oh, the locknuts will be forfeit though (basically they smash a wheel brace on them with a hammer and undo them, so they become useless).
furry m*ff. Yeah i'm happy to help
Cool thanks :thumbsup: I'll let you know when I have a head unit. Just let me know what bits and pieces I need to buy for the kill switch and drift switch
so true about everyone being into limp bizkit at some point!
no it's not :)
    • Basically your tuner needs to drive it for the 30 min (or whatever) to create the same conditions then check the ECU settings and sensors at that time. They may not be excited to because that takes them 30 min rather than just opening the bonnet and seeing the problem straight away.... Hot start is generally not as tricky as cold start, but there would be a table for fuel enrichment vs coolant temp as a starting point
    • Yeah, they all cant say anything for sure as everything is working fine . Said unable to find an issue untill it stops again. Could mist likely be CAS wiring or IAS valve issue but again not 100%
    • Who tuned it? Have you spoken to them about the hot start issue yet?
    • injectors were upgraded (1000cc), stock turbo high flowed, return flow infercooler and ecu nistuned before tuned
    • Injectors? Note, there is no way that I would run E85 on stock injectors. They are too small.
