Im prob just reading this wrong but this is what I found.
The GTS-t Type M included larger five-stud 16 inch wheels, four piston front callipers and twin piston rears. ABS was optional (except for the GT-R), viscous LSD was standard on all turbo models and optional on all but the GXi. Nissan also produced 100 Australian models of the R32. These were the only non-Japan only Skylines ever produced. There was also a 4WD version of the GTS-t Type M, called the GTS-4.
Please explain :)
Just so you all know.. HAVE YOU EVER SEEN A GENUINE TURBO! R32 that wasn't a Type-M.. No, you havent. They all have 4 pot fronts and 5 stud hubs. It's just a marketing hype.. All friggen turbo R32's are Type-M's with different trim levels, just like options and trim levels on any other car.
Please explain :)
Learn about full stops. :D
The 100 Australian models were GT-Rs. They weren't produced in Australia though (AFAIK), they were produced in Japan but locally delivered by Australian nissan dealers (To be fair this information is not described in that quote). The bit aboute the GTS-4 is the next sentance and is unrelated to the previous.
It is definitely poorly worded. Just goes to show you can't always trust wikipedia
Ah k cool bananas :D
Yeah I obviously dont know much about cars thats why I was asking if that stuff was right :down:
ROLL CALL!
my brothers formal is on tuesday night - and as he was discussing a few weeks ago he was hoping if we could all do a drive thru for him
he wants to get there at 6 and its being held at the hilton in the city
hopefully some of you guys can help him out :)
ROLL CALL!
WWWWWWWWWWAAAAAAAAAAAAAZZZZZZZZZZZZZZZUUUUUUUUUUUUUPPPPPPPPPPPPPPPPPP!!!!!!!!!!!!!!!!!!!!!!!!!!!
so thats a yes?
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
