ROLL CALL!
my brothers formal is on tuesday night - and as he was discussing a few weeks ago he was hoping if we could all do a drive thru for him
he wants to get there at 6 and its being held at the hilton in the city
hopefully some of you guys can help him out :D
This tuesday? damn, wish you'd asked a couple of days ago :)
I'll try to get out of cricket, but it will depend how many people want to play
GTS4 ? ? ? Is that the AUS made RB20det wit 4wd ? ? ?
JDM
The GTS4 is essentially a poor man's GTR. When Nissan released the GTR, the Japanese folk who lived in the mountainy areas with the rough roads and snow and crap really wanted them, but couldn't afford them. Nissan built an RB20 powered, heavier version of the GTR. The GTR uses all the fancy aluminium parts for some panels, and running gear etc. The GTS4 uses steel. So basically: it's the standard GTST body (so not wide body like the GTR), with the ATESSA 4WD from the GTRs, single turbo RB20.
GTS4s are less common because it is hard to find ones that aren't rusted out due to all the snow and salt.
Whats planned for it? I have such a soft spot for gts4's. More so when rb20's are kept.
The little motor that could!
For now, probably just a brake and turbo upgrade. HICAS lock out, drift switch. Cosmetic changes.
Down the track I'm going to look at a different engine (maybe a 26)
ROLL CALL!
hopefully some of you guys can help him out :)
If I have my car by then, I will. If I don't... well let's just say I aint walking.
ROLL CALL!
so like just a drive by ?
    • I did basically the same procedure on a ZF6HP but the reason to pull the valve body is to replace the seals between the valve body and the transmission which are notorious for leaking pressure with age causing poor shifting and burning out the clutches. If you just wanted to exchange all the fluid you should be able to undo one of the transmission cooler return lines to drain into a bucket while using the pressure filler to keep it topped off.
    • The title should have posted "EFR7670 exhaust housing selection RB26" I can seem to edit thr title on my Android.
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
