Sounds like the regulators fuxed. Cheap and easy fix (y)
*shrug* I went home
Doesnt matter. Anything that does ON and OFF. Figure out where and how u want to mount them, and get something to suit
Ok cool. I'll raid some parts bins before the weekend
Awesome :)
No remote start though :P Don't think I can hook it up to it either :(
Yeah cut and solder. Thats what monkey boy is for
Okie dokie!
Not particularly, easy for purchasing though :ninja:
Lol, yeah I meant easy to go and get one
f**king splits! c*nts to install. Get them physically mounted during the week if you can... Then we'll just have to do the electrics on the weekend
They're the ones out of my old Navara... they were easy to install in that. We might be lucky, and the tweeters in the doors might have survived, if not... the tweeter pods are at least already on the doors. The crossovers should be able to fit on the inside of the center console behind the head unit - plenty of room in there.
F**K it, I'm out :ninja:. Naah all good I guess, will just work slower. Shame about the JB but :(
It is a shame :)
I was waiting for a pic of miss molly :(. But hell yes, DO IT!
Oh crap! I'm sorry... that was a terrible let down!
That means twice as many wires to the doors :)
You're forgiven :ninja:
That means twice as many wires to the doors :ninja:
Not if we tape them together and feed them through in one go :)
Depending on speaker price, I might just get some 6x9s for the front and 7x10s for the rear. I'll see how I go.
Any ideas for amp placement?
Edited by Isola
dash mount, john im better for sunday, i have a large list of jobs to do on saturday, most important of them is do my wheel alignment and gas my aircon in the car. Gotta love having a full air conditioned workshop to play in!
Not if we tape them together and feed them through in one go :D
You'll be better off with the splits, really.
Under a front seat? In boot?
/Callvote take johns car to dan's workshop to wire shit
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
    • This. The R34 handbrake icon DOES come up when the brake fluid level is low. You might be sitting right on that threshhold. I have been down this diagnosis path and this was the solution (and it was pretty much as full as your picture is to begin with).
    • Unfortunately the cavaet to that is that while any scan tool should be able to read the code, the workshop will need a consult plug to OBD socket adapter. You don't have a location on your profile, where are you based?
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
