Brandon, Its a nismo version of the Z32 AFM so it still needs a plug, where as the Nismo version of the GTR AFM has essentially z32 internals (reads up to .5V) so the main difference is that a z32 based nismo AFM is 80mm in diameter whereas a GTR based nismo AFM is still only 65mm. As for spray pattern im not sure what you mean as all it does is measure air volume!
and for the boost question yes it is possible for boost to spike if the solenoid does not react fast enough
Oh and if i can get $350 for each AFM and $800 for my shitty power FC i will be happy! Good ecu here i come!
$200 for the afm, and icecream, a 6pack of beer and one of my special cuddles..
Back in your hole
That's what she said
worked out I can free copies from work :P
oh? how many? :D
better spray pattern
80mm in diameter
spray pattern
lol
Got my first pull over this morning.
Came out of maccas at aspley onto Gayford St, and they followed me onto Albany Creek Rd.
Pulled me over just past the 711 servo.
"Where's your rego sticker?"
'Just got her registered yesterday'
"Where's the rego papers?"
'....shit... probably still at the dealer' :D
"wait here"
*goes and does something in his car. Probably just sat in the air con... stupid heat*
"righto. all checks out fine. Grab those papers if you can mate and keep them in the car till the sticker comes?"
'yep, no worries. I'll head down there today'
The only bad part was as they were leaving the one who'd been quiet the whole time goes "this is sitting pretty high for a skyline isn't it?"
you can't fail harder than having the cops tell you to LOWER your car hahahaha. It's worse than when the motorbike guy told Colin he needed more low :P
thats pure gold
great news that the 32 is on the road mate :D
Thats awesome :P
Dan tells me the cops approved of my XF last night too :D
I'm sure you'll come very close even if you cant get those prices. Only tough part is AFM would be hard to sell at those prices since its natural human thinking of paying the "2nd hand price".
The spray pattern can be like windscreen cleaner. Jet or spray. I'm not saying its that but you should get what I mean. Forgot those threads but there's a few that goes on about
http://www.skylinesaustralia.com/forums/Sa...Rb-t294052.html
Yeah but an AFM = Air Flow Meter. Not and injector. Different part Brandon :D All the AFM does is measure the amount of air going into the engine and tells the ecu how much fuel to squirt in.
You are talking about injectors you silly bugger, we are talking about Air Flow Meters!
brandon you're so cute
OMFG!
I just realised that... HAHAHA!
What was I think... yea I know AFM is air flow meter... my head must be thinking of injectors all the time for some reason.
I'm an idiot.
OMFG!
I'm an idiot.
thinking injectors cuz u want to buy some? :D
im excited
:P
Just got back from the shops and some c_nt has put a lovely big ding in my door.
God I hate 4wd owner's I really do. I think they all should be shot then stabbed then stabbed again before being shot.
:banana:
Serenity now, serenity now.
Ah,
:D
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
    • The fact that US/JDM plates actually fit the skyline bumpers properly is a big, big thing for me as they are the correct dimensions. Annoyingly you can't opt for a normal plate (or plate combination) in that size. You have to make up your own one, and at that point you'd still know it wasn't randomly assigned.
    • Well, really, that's any ECU, because it's not so much the ECU that the tuner connects to, but a laptop that's connected to the ECU. You have to have the tuning software installed locally. The "remote" part is essentially just remote desktop (RDP) or VNC type access. Nevertheless, if you're looking to upgrade, then you're immediately in the Haltech/Link territory, both of which can be done by any number of competent tuners here in Oz. But without a dyno, you'll definitely also need a wideband O2 sensor fitted, and you'll probably be relying on "auto" tuning a bit, where you drive it around under various loads and then apply the corrections that the ECU learns (basically applying the fuel trims that the ECU has to do to correct the mixtures). Tuning the timing is a little harder. It can be difficult to trust the old OEM knock sensors on RBs, so it is definitely best to have someone who knows what they're listening for, with knock ears (a piezo microphone connected to the engine, and and little amp and headphones so the listener can hear the angry men with hammers who live in the engine). That is more difficult to do remotely, and I suspect the only sane way is to be quite conservative on timing. But that's OK. You're probably waaaaay better off with conservative timing where you are. What is the fuel situation? 98RON available? Or low grade jungle juice?
    • I see your point, I didn't think too deep into it, was purely focused on the price. There's no bad blood between myself and GSM, they acknowledged the price was cheaper else where and at the time couldn't match it.
