Brandon, Its a nismo version of the Z32 AFM so it still needs a plug, where as the Nismo version of the GTR AFM has essentially z32 internals (reads up to .5V) so the main difference is that a z32 based nismo AFM is 80mm in diameter whereas a GTR based nismo AFM is still only 65mm. As for spray pattern im not sure what you mean as all it does is measure air volume!
and for the boost question yes it is possible for boost to spike if the solenoid does not react fast enough
Oh and if i can get $350 for each AFM and $800 for my shitty power FC i will be happy! Good ecu here i come!
$200 for the afm, and icecream, a 6pack of beer and one of my special cuddles..
Back in your hole
That's what she said
worked out I can free copies from work :P
oh? how many? :D
better spray pattern
80mm in diameter
spray pattern
lol
Got my first pull over this morning.
Came out of maccas at aspley onto Gayford St, and they followed me onto Albany Creek Rd.
Pulled me over just past the 711 servo.
"Where's your rego sticker?"
'Just got her registered yesterday'
"Where's the rego papers?"
'....shit... probably still at the dealer' :D
"wait here"
*goes and does something in his car. Probably just sat in the air con... stupid heat*
"righto. all checks out fine. Grab those papers if you can mate and keep them in the car till the sticker comes?"
'yep, no worries. I'll head down there today'
The only bad part was as they were leaving the one who'd been quiet the whole time goes "this is sitting pretty high for a skyline isn't it?"
you can't fail harder than having the cops tell you to LOWER your car hahahaha. It's worse than when the motorbike guy told Colin he needed more low :P
thats pure gold
great news that the 32 is on the road mate :D
Thats awesome :P
Dan tells me the cops approved of my XF last night too :D
I'm sure you'll come very close even if you cant get those prices. Only tough part is AFM would be hard to sell at those prices since its natural human thinking of paying the "2nd hand price".
The spray pattern can be like windscreen cleaner. Jet or spray. I'm not saying its that but you should get what I mean. Forgot those threads but there's a few that goes on about
http://www.skylinesaustralia.com/forums/Sa...Rb-t294052.html
Yeah but an AFM = Air Flow Meter. Not and injector. Different part Brandon :D All the AFM does is measure the amount of air going into the engine and tells the ecu how much fuel to squirt in.
You are talking about injectors you silly bugger, we are talking about Air Flow Meters!
brandon you're so cute
OMFG!
I just realised that... HAHAHA!
What was I think... yea I know AFM is air flow meter... my head must be thinking of injectors all the time for some reason.
I'm an idiot.
OMFG!
I'm an idiot.
thinking injectors cuz u want to buy some? :D
im excited
:P
Just got back from the shops and some c_nt has put a lovely big ding in my door.
God I hate 4wd owner's I really do. I think they all should be shot then stabbed then stabbed again before being shot.
:banana:
Serenity now, serenity now.
Ah,
:D
    • This. The R34 handbrake icon DOES come up when the brake fluid level is low. You might be sitting right on that threshhold. I have been down this diagnosis path and this was the solution (and it was pretty much as full as your picture is to begin with).
    • Unfortunately the cavaet to that is that while any scan tool should be able to read the code, the workshop will need a consult plug to OBD socket adapter. You don't have a location on your profile, where are you based?
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
