Isola you putting a remote start alarm system on your car ? If so, do you know where the relay is so that the car doesn't start in gear ?
*end serious note back to reality*
oh look a duck.
nah, no remote start for me :D I wanted a remote start alarm, but really just needed an alarm in and going to insure the car. Kinda just planned on keeping the mongoose for a while and changing over down the track. Kinda wish I had have just gone with the one I wanted from the start now though. To answer your question - just leave it in neutral all the time like I do :)
my serious question - does your remote start work when the steering lock is on?
*general ramblings and suggestions*
At this point in time, I highly doubt the boot an bonnet pins are wired up/even installed. Figured the doors would have at least been something standard that was done on every car. Need to get it sorted out ASAP though, because my insurance doesn't actually cover me unless I have an immobiliser AND an alarm installed.
Granted I've not yet checked the power steering fluid, but I figured it'd be full because everything else was when I bought the car. And knowing my luck, it's more likely to be the pump. No warning light on though (don't know if there is even a warning light for it on the dash?) Not the end of the world as I hate power steering anyway... it was just that it was one more thing to frustrate me after getting raped by the auto electrician.
Hope you find a unit soon dude. Share housing sucks hairy jew nuts :)
also john - i think ive found those wheels you were after
enkei rpf01
Not them, but thanks anyway dude.
thanks for the input guys. there was something else I was going to say but can't remember... *shrug*
nah, no remote start for me :) I wanted a remote start alarm, but really just needed an alarm in and going to insure the car. Kinda just planned on keeping the mongoose for a while and changing over down the track. Kinda wish I had have just gone with the one I wanted from the start now though. To answer your question - just leave it in neutral all the time like I do :D
*puts on serious hat and pipe*
The remote start that I have will start the car with the steering lock on and if the car is in gear. But with the relay switch if the car is in gear it clicks on and disables the remote start. The relay switch was a option that they put in for me as apparently its illegal to have a remote start on your vehicle if it is a manual as you can start the car in gear and watch it merrily drive down the road.
*removes pipe*
I kinda meant seriously...
no wait nevermind... my mind just processed that I never knew what Dominos she was working at... so obviously that's what it is.
Edited by Isola
john if you want a good auto electrician try toowong car electrics in black street milton, not sure what he charges but he does our stuff for work.
You still got hicas too yer? maybe got a leak in the system there somewhere. I say lock it and new pump to a rb25 pump
Dan - thanks for the tip. I might check them out next time. Right now though auto electricians are on the top of my kill list.
so... for those of you playing along... an update on the FO':
Power steering is probably the belt. We forgot to change it :)
Brake lights - still playing up
Reverse lights - still playing up
Head unit - now wired up and working like a dream thanks to Jack at Phantom Motors :) (side note for Martin & Dan: My pioneer speakers are rooted, so I need new 6" speakers. Just going to buy 4 6" speakers the same and save the headache of trying to get those 6x9s in the doors).
Amp - working fine
Dome light - working
Headlight - still need new globe
Map lights - still need one globe
Paintwork - filthy - car wash tomorrow night? :dry:
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
