So after playing around with my new head unit for a while:
Custom background
Album art display
Track, Artist and Album info onscreen
Movies
And epic skids!
:) :) :dry::cool: :cool:
look at them cheer for me
Yo dawg, we know you like music and cars. So we put a car in your radio in your car, so you can listen to music while watching driving while your driving.
Dan - thanks for the tip. I might check them out next time. Right now though auto electricians are on the top of my kill list.
so... for those of you playing along... an update on the FO':
Power steering is probably the belt. We forgot to change it :dry:
Brake lights - still playing up
Reverse lights - still playing up
Head unit - now wired up and working like a dream thanks to Jack at Phantom Motors :cool: (side note for Martin & Dan: My pioneer speakers are rooted, so I need new 6" speakers. Just going to buy 4 6" speakers the same and save the headache of trying to get those 6x9s in the doors).
Amp - working fine
Dome light - working
Headlight - still need new globe
Map lights - still need one globe
Paintwork - filthy - car wash tomorrow night? :cool:
Can't say I blame you
FO'!
Easy fix. I'd be doing a fluid flush too though, unless it looks really clean or you are sure it has already been done
Damn :(
Damn :( Anyone know if a GT-R reverse switch is the same as standard R32?
Awesome :cool:. But you do know we cut up the bits of wood that mount 6" speakers in the door right?
Sweet. Dan is now solder monkey + Amp repair man
Sweet.
Hit up super crap. Unless you want quality or white/blue light. Then hit up ebay
See above.
Im working late AGAIN this week :( So hopefully you dont all p*ss off to the carwash too early
It wasn't grounded
ORLY? I was sure getting a voltage on my multimeter. Oh well, glad its sorted :)
hahah, damn. That auto sparkie you went to is crap.
In other news, pirate metal is awesome music
+1
+1
+1 for pirate metal
+2
HU of win. Do want
F**KING LOL
john if you want a good auto electrician try toowong car electrics in black street milton, not sure what he charges but he does our stuff for work.
You still got hicas too yer? maybe got a leak in the system there somewhere. I say lock it and new pump to a rb25 pump
+1 for Toowong Car Electrics.
Sean taught me most of the fundamentals I know about Auto Electrical.
f**k the price, get the job done right!
im more into Lucy Pinder, or maybe Kim Kardashian, or if i was in a cougar mood perhaps Monica Bellucci or Cathrine Zeta Jones
+1
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
