So after playing around with my new head unit for a while:
Custom background
Album art display
Track, Artist and Album info onscreen
Movies
And epic skids!
:) :) :dry::cool: :cool:
look at them cheer for me
Yo dawg, we know you like music and cars. So we put a car in your radio in your car, so you can listen to music while watching driving while your driving.
Dan - thanks for the tip. I might check them out next time. Right now though auto electricians are on the top of my kill list.
so... for those of you playing along... an update on the FO':
Power steering is probably the belt. We forgot to change it :dry:
Brake lights - still playing up
Reverse lights - still playing up
Head unit - now wired up and working like a dream thanks to Jack at Phantom Motors :cool: (side note for Martin & Dan: My pioneer speakers are rooted, so I need new 6" speakers. Just going to buy 4 6" speakers the same and save the headache of trying to get those 6x9s in the doors).
Amp - working fine
Dome light - working
Headlight - still need new globe
Map lights - still need one globe
Paintwork - filthy - car wash tomorrow night? :cool:
Can't say I blame you
FO'!
Easy fix. I'd be doing a fluid flush too though, unless it looks really clean or you are sure it has already been done
Damn :(
Damn :( Anyone know if a GT-R reverse switch is the same as standard R32?
Awesome :cool:. But you do know we cut up the bits of wood that mount 6" speakers in the door right?
Sweet. Dan is now solder monkey + Amp repair man
Sweet.
Hit up super crap. Unless you want quality or white/blue light. Then hit up ebay
See above.
Im working late AGAIN this week :( So hopefully you dont all p*ss off to the carwash too early
It wasn't grounded
ORLY? I was sure getting a voltage on my multimeter. Oh well, glad its sorted :)
hahah, damn. That auto sparkie you went to is crap.
In other news, pirate metal is awesome music
+1
+1
+1 for pirate metal
+2
HU of win. Do want
F**KING LOL
john if you want a good auto electrician try toowong car electrics in black street milton, not sure what he charges but he does our stuff for work.
You still got hicas too yer? maybe got a leak in the system there somewhere. I say lock it and new pump to a rb25 pump
+1 for Toowong Car Electrics.
Sean taught me most of the fundamentals I know about Auto Electrical.
f**k the price, get the job done right!
im more into Lucy Pinder, or maybe Kim Kardashian, or if i was in a cougar mood perhaps Monica Bellucci or Cathrine Zeta Jones
+1
    • Was going to say the car pulls up nicely everywhere, especially going into that last long right hander before the main straight. Looks like a lot of fun.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
