Found out from a mate that there's a guy in briz vegas that chops rims an makes em wider . . . Anyone knw about this ?
ive heard about someone making a wheel have more offset by like welding on spacers or some shit
sounds backyard to me man and backyarders are dodgy
Your life depends on the 4 wheel! No dodgy... noo......
Hahaha... I didnt realise the offset. I still dont get it though. What I've gathered is most common offsets are greater than 20 and for most it'll be above 30.
Someone gotta gimme a lesson on it someday.
The Harrys meet might be good tonight. HATE TAX and 57NGR seems to be going too... Hahaha. Chicken Schnitzel here I come!
For those that MIGHT be interested, Adam (brizzy_rocker), John (yaface) and I will be there for dinner.
old lessons for old brandon
lets just say a 7" rim with a 45 offset is epic epic fail
so now you can see why the lower the offset - the more the wheel will stick out of the guard
Oh nah I dont want that, this guy chops em and welds pieces in the middle to make the wheel wider on the inside so you can fit bigger rubber on :blink:
so just as an example; all these rear wheels are 9" ok, but with different offset
+30 offset
+20 offset
+10 offset
0 offset
-5 offset
now yes the guards and profile/width of tyre can vary n shit - but you get the general idea
class dismissed
Oh nah I dont want that, this guy chops em and welds pieces in the middle to make the wheel wider on the inside so you can fit bigger rubber on ;)
personally i'd sell your wheels and get new ones which are correct width/offset etc
Still dodgy. It'll be even worse if you have a high powered car. Anything thats broken (intentionally or unintentionally) will not be as strong which is why 1piece forged rims are so exp.
Tris: guess what? I'm an idiot again, seems like always managed to go on the wrong channel all the time. I thought you were referring to the offset when you said 7... HAHAHA. Yes, 7" wide is fail. Fit maybe 205? I wish mine were like colin's 10.5 ;)
If you find that pic of my car you will see what 17 X 9 +24 is like. Althought I have rolled/flared the guards a bit.
What are they anyway?
Back on those pic, yea I sorta figured out the difference between positive and negative offsets but I remembered someone told me its related to dish. Say if you've got +22 and +15 on the same wide and size rim, the +22 will have more dish and this is what confuses me. What I understand from looking at those cross sectional diagrams is the offset's got nothing to do with the dish size, its the width and rim design that dictates it. What offset does is determine how much your wheels will stick out or in from the hub.
correct...cause spacers are for LOSERS!!
Not really man.
Simon's wheels are some of the strongest and most expensive and some of their models are 3 piece. They are made to your order though.
Forged rims are expensive because they are strong and light.
You might also find that some welded connections are just as strong as some metals....but you can't cut and weld forged rims, because they are magnesium alloy, because it weakens the alloy. Steel rims you can.
Dish man, is just a term for what some wheels have when the spoke doesn't protrude to the edge of the mag. For example. An XD9 Work rims has dish...and XT7 work rim does not. even though they can be gotten in the same size....dish is just a wank term used to discribed the flat surface between the spoke and the edge of the wheel.
My rims are Volk GT-AV - 19" x 8.5F, 9.5R not sure what the offsets are though the back fits perfect with f**k all camber and the front are about 10mm inside the gaurds
Yeah Im not a fan (got none on mine) but it is hard to find wheels that fit perfect
im more into Lucy Pinder, or maybe Kim Kardashian, or if i was in a cougar mood perhaps Monica Bellucci or Cathrine Zeta Jones
Lucy Yes, Kardashian doesnt do it for me at all
over. rated.
True
John: http://www.boostcruising.com/forums/index....=485760&hl=
Pretty good price and looks good too!
Fail width, Fail offset
ugh shit i just saw that those bc's are 17*7 fail!
+1
Think thats for steelies mang. 3 piece rims you can get new outers for, but they are not chopped.
+1
Was going to go into this but seems its been covered already
Harrys fail ;)
Good job
    • Resizing injectors in Nistune can be done a couple of ways, and there are a couple of ways that you can make a mess of it. The tuner needs to be really aware of the effects of whichever approach he uses (either K, or TIM). They are both easy enough to "get the injector size right" to run the engine. But little details like old start enrichment and hot start are affected differently, depending on which boxes you check.
    • Pretty safe to say almost everyone that has tuned their own car has experienced this issue. The difference being that we have our laptop in the car and when it happens, it's literally 10 seconds of tuning to sort it.  Would you be happy to plug in your laptop and sort this yourself? It is a very simple process and there is no risk of harming your engine (if you are worried about that).
    • Yeah thats the next step now, either they wil or i will take out for a drive to work and go straight their after work and see is we get the same issues 🤞  thought i try my luck here too, never know someone else might have had the same issue but thanks for the reply
    • Basically your tuner needs to drive it for the 30 min (or whatever) to create the same conditions then check the ECU settings and sensors at that time. They may not be excited to because that takes them 30 min rather than just opening the bonnet and seeing the problem straight away.... Hot start is generally not as tricky as cold start, but there would be a table for fuel enrichment vs coolant temp as a starting point
    • Yeah, they all cant say anything for sure as everything is working fine . Said unable to find an issue untill it stops again. Could mist likely be CAS wiring or IAS valve issue but again not 100%
