I'm at work too thats why I'm checking if anyone wanna go and check it out.. -.-;
http://www.boostcruising.com/forums/index....=485901&hl=
This is for you 4studs tractor.
thanks mang but i have my eyes on some other wheels, just got to trial fit them first
buhaha yeh john i was past 5K in 3rd gear when i passed you, but then i got the chills when i shifted to 4th gear, the crunch f**kin gives me the scares man, depending on how much monies il have later mayb get the OS Giken Gear set, but most likely replace with all geniune synchros.
oh and yeh the road was bloody empty on the way home, constant 120 km/h in 5th gear, i just get back on the highway and then go through Mt. Gravatt and then Logan Rd to the city then Milton then St Lucia. how to do u guys get home from the right turn on the signal? where does tht road take yaz?
Where the GTR boys turn, I do a Uturn, and head back to the SE Freeway. Or sometimes I go back the way we would go from baskins and drive home via toowong.
I still dont understand why they have them in miles when most of the world have f**king kph on our speedo.
I'm only going to say this once, so Brandon... you need to actually read it.
It's a quarter MILE. It's not a quarter Kilometer.
Yep i am also on the gubberment internets. No pron's for me. Damn. No good fun stuff either. Damn. So I give you this...
http://i.imgur.com/FvtQv.gif
SFW.
Lol... I could stare at that for hours
Would look good on the cop.
Pub lunch is on like Donkey Kong.
work BBQ this arvo :P
anyone want a welded diff?
f**king lol
That has to be a piss take surely nobody is that dumb.
Tristan, are you rebuilding your self or buying a new engine (either rebuilt or stock)
If rebuilding my advice is......spend shit loads of time on the head because ours was not put back together properly and it caused us ALLLLLL kinds of grief!
Have you met people before? Plenty of em are that dumb :P
Where do you work smity ?
Powerlink - QLD's high voltage power network
Thats what she said?
Have you met people before? Plenty of em are that dumb :)
I've met people.
+1
I'll call it a 400m dash.
Similiar to the 100m dash we have in sprints. :D
Is it lonely there in Brandonland? :P
So your the one running in the little wheel making all the power ?
I've met people.
+1
Not really. You join in?
That reminds me, there's a regional suburb in queensland thats called Brandon.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
