@John: If you haven't sorted your alarm yet, check the "programmable options" . You know how i said my boot alarm wasn't working, well it turns out, neither were the doors or bonnet :S. Turns out the settings had got reset at some stage and "Turbo Timer Support" was turned off. So when i locked it with the engine running (on timer), it was just locking the doors and not arming the alarm. All good now, maybe yours is a similar issue?
Cool. I'll check it out.
Apparently the guy who was asked to install an alarm/immobiliser didn't install a siren though... OR hook it up to the horn in place of a siren... so who knows what else he took liberties with. But I'll check it out anyway :D
ps second pic looks weird cause there was a existing dint in the quarter. have not finished the other side, fronts however are done.
Edited by 32_Dave
Afternoon all. Sorry for my epic fail last night lol. I got all my shit packed today. Only things left are clothes for the week and bed lol. Fun times ahead.
Yeah... thinking that might be the case because $500 for just an immobiliser is pretty steep :P
your basic m80 mongoose setup is under 200bux to buy outright. and if its the same guy that did tristans 180 id be making him re-do it while i watched... f**king appalling.
i just watched you re-wire mine, twas amazing :P
so neat, so tidy
Been at work for an hour and bored already :P going to be a long week, and a very long 3 weeks till christmas :D
My weekend was good (except for the lack of touge). Got my alarm sorted (although my boot release is proper fried, it won't be working without replacing the alarm unit), got my bonnet struts installed (MASSIVE win!), and spent far too much time sitting in A/C playing silly computer games :P. Oh, and my witch of a housemate moved out, and the new one seems to be at least slightly less anoying.
That whore!
Martin: come along to the SAU drag day on the 12th. At least that'll be 1 thing to look forward to for a week. And tomorrow is pay day! Thats 2 weeks down.
    • Hi. This is just my curiosity because iam sure the tuner figure something out...but either way i want to ask. The "problem" is that the Nistune ECU (Stagea FW and RB25DET NEO from Stagea) sees many times the speed than the speedo does(he says the speedo show 120 km/h - correct speed and the ECU shows like 510km/h ) I told him that this car/tranny getting speed from rear diff. If iam not mistaken the RB25DET NEO "need" to see tranny speed sensor? (my tranny has the plug for it). So couple of "question" If he connects/wire the speed sensor to the tranny...are the signals gonna intervene and if...what if he disconnects the rear diff one and the speedo stops working? Or the "new" sensor from the tranny "take over" and will not going need the one from diff? As i said i know he figure/get that done...iam just curious to know what are the solutions 🙂
    • Your IACV is set to idle too low. You need to adjust it via the screw Duncan mentioned. From memory it should be 650rpm with the valve electrics unplugged. What is it trying to idle at with the IACV plugged in?
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
