We do cam4 shows, payment via paypal.
Oh make me pay for it hey? :P
Martin: come along to the SAU drag day on the 12th. At least that'll be 1 thing to look forward to for a week. And tomorrow is pay day! Thats 2 weeks down.
Drags are for women :D. I'll possibly come along if ive got nothing better to do that week, but I won't be entering.
:P dont start me
RB20 time?
I'll give u a free one in exchange for colin's sister
josh has that video, we filmed it at his place,
i believe he is converting it to a mpeg today for us :P
Drags are for women :P . I'll possibly come along if ive got nothing better to do that week, but I won't be entering.
RB20 time?
o.O
I wonder where did I saw the 400m dash slip from. hmmm...... maybe from a drag queen.
Went out once with the 31 boys for luls. Decided it was a sport of fail. Won't do it again, untill I feel like more luls.
P.S. GT-Rs belong on the track, not the drag strip, get out there next year!
Hahaha.. I will dont worry, when I got the suspension done late next year.
Not a big fan of drag too but hey, there's always a first time for most things. I dont really want a f**ked clutch from the launches but at the same time I wanna feel hows it like to launch it at 7000rpm too. Probably gonna do it once or max twice for that day.
Hmmm... I've tried 5k launch by slowly releasing the clutch instead of dumping. No wheelspin at all and feel pretty good actually. Clutch still very good imo. No slip and still bites the same. But having said that, I got the 7k and dump from Dirtgarage and Andy (Bunta). But I'll talk to the boys on the actual day itself before I actually do it. I dont have plans on a new clutch at the moment.
Work :'(. no utube.
I'm just thinking stock car, 7,000rpm launch, can't end well? But I may be wrong...
yeeeh, wouldnt it be like *dumps clutch* BAH BAH BAH BAH..... BAAAAAASMASH!
*gearbox drops out the bottom of the car...*
Theres also gearbox, transfer case, tailshaft, driveshafts to worry about...
Thats what I would expect, but GT-Rs are awesome, so maybe they are capable of it. I don't know
they are, but a 7k launch is a 7k launch - which is cronic
brandon i have a vid for you im just looking for - you'll jizz
i cant find the one im looking for,
but for you guys who are into drag - go toyota
proof:
yeh you might have seen this - but its still jizz-tastic
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
