Martin: What do you do at powerlink? Please dont tell me you're running on the wheel.
I run on the wheel :(
Lol, you haven't done anything. Colin will explain.
I have a fairly dry sense of humour.
Fair enough, was just checking i hadn't accidentally p*ssed you off by nailing your sister or something :O
FYP
LOL
thats as long as josh lasts
i was disapointed too
Me too :P
P.S. Brandon: I'm in IT, I work on their drawing management system.
I'll probably apply for powerlink if the pay is no good after this graduate program finish this year.
Wheelies FTW!
Maybe origins too. Hahaha.
what do they use? Is it their own system or a third party one? We use Aconex at work n it's not too bad. Some good features but most subbies are computer illiterate so it's wasted on them.
You're in a grad program? When did you finish uni?
bonus of doing a cadetship is I get to skip the graduate stage lol :(
10 hours give or take without complications to do it properly.
So give or take 900 - 1000.
Or half if I give you a a car with no motor to pull out, give or take.
Yea. Finished uni in 2006 and started the program in 2007. So this year will be the last and they'll handing out the contract sometime this week or next. :x
Wheelies FTW!
I don't actually work for them directly, I'm there as a contractor/consultant so I can't help you out with an in sorry. What kind of work do you do?
Its a 3rd party one, I actually work for the vendor so I won't go into details.
Nah I'm just saying I'll probably be apply for energy companies if it does happen. But my expectation arent high so chance of me applying for another job is low. I'm an electrical engineer.
Oh wait. T +5mins! Time to head home. Cya!
oi martin - i just signed into msn on the work computer and i have all theses conversations from you that i didnt receive lol!
i think my mac hates you cuz u dog it hahahah
Money for mods soon. WOOOT! :(
Lol i stopped talking to you coz i thought u were dogging me.
I guess I'll try talking to you when ur actually online or something :(
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
