It comes with a free bit of paper with "RB25" written on it :down:
Why are you selling your Bee*r?
On a side note, car is going to city suspension centre tomorrow for more low, camber adjustment and wheel alligment
new tyres from bosman tyres coming on saturday.
money money...
hahaha fair enough
coming out on thursday to show us the new epic low?
yeh, should be out there for my usual gym followed by energy drinks and bnr action
Because the last time I was there it looks like one way ticket to defect. I dont mind sitting in colins car and park at mirage or something though. :down:
What about a set of R33 rims? Throw them in?
I've seen your stuff for sale just sit here forever. You should accept it.
stab much? come play with the big boys one day and learn how to negotiate.
Isn't the exhaust the only thing on your car that's a bit naughty?
I don't haggle. People can advertise their stuff for what they want, and best of luck to them selling it at that price. If I want it for that price, I'll buy it. If it's not at a price I like, I'll go elsewhere. Haggling is just an insult.
So you "big boys" can "negotiate" all you want. I'll keep my manners and my respect for other people's wishes close to hand though thank you muchly.
ever herd the words "there is no such thing as RRP or asking price" sometimes yes you gotta fork out if you really want it, but 9/10 times you can bargain it.
Because the last time I was there it looks like one way ticket to defect. I dont mind sitting in colins car and park at mirage or something though. :P
Dunno if my car will even be there now :) Guys at beaurepaires didn't want to fix the tyre because it has cracks in the sidewall. Gunna try and get it fixed elsewhere tomorrow but I'll probably be there at Baskins in the Prado.
Yeah. From hagglers. :P
And it's not even like you NEED those rims. You're selling FOURTEEN rims. It'd be different if you'd buckled your rim and were short on cash and really in a bind and needed something quick smart. But that's not even the case. You just want them for nothing so that you can profit from it.
Fwah! Maybe drive around slack creek and check every tyre shop? There's an Asian one (tyre works no. 43 moss st) just across the road from autobarn which my friend knows the owner. Dont know if they will repair too but no hard trying. Tell him Colin Liu referred you to him.
Prado touge!!
let's see if we can get it up on two wheels! :P
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
