Tristan: Swing by and say hi. You still up for saturday fish and chips?
Colin: Ah well fair enough. Anyway still waiting on Michael. Its John, you and me for now. The 3 musketeers
No no, i want more internets. Will provide you with petrols. Exchange rate is fair though, happy to provided 1 petrols in exchange for 4 internets.
Done 4 internets for 1 petrols. Wait a minute I was the one wanting more petrols now I'm one petrols less..
damnit
i thought i already said i gota bail on fish and chips?
ill be more available when i can work less and the 180 is sweet :P
hi all, im new to this thread. Came across this thread title and as im from the brookfield area, i would love a chance to meet up with people in the hood so to speak. do you guys meet up regularly? sorry there are over 500 pages of chit chat and cbf reading it all. if any guys (or gals) in the area would like to meet up to friendly talk skylines, please drop me a pm! would love to meet you guys (and gals)
Edited by AtomicBomberMan
730 tonight at chapel hil baskins i believe man
CA18 is a twin cam
yeah... the later ones. Sorry, when I hear CA I always think SOHC. I keep forgetting they made a DOHC later on.
not true - a rebuilt forged CA can handle 20psi and a 3071 = cronic baking the whole of qr
CAs are only decent if they are rebuilt and forged
Yeah, so? So can an SR (usually just with a t28 upgrade you can safely run between 13-20) - it just sounds like a C17 the whole way around the track. :P
you do realise you just put the t28 and the 3071 in the same boat... they are leagues apart
I did no such thing. I never once mentioned an R33.
We're talking about two different engines and two different turbos running a certain level of boost, that certain level, just happens to be similar.
the secret to flood control is to make a donation
Orly?
damnit
No wait I'm giving you one petrols and ur giving me 4 internets.
5 or 10 dollars
best money spent
no flood control and more pm room
Now you tell me!
Edited by Smity42
180SX 5 SPEED TURBO
6 MONTHS REGO & RWC
CA18DET
T28 TURBO
S/STEEL LOW MOUNT MANIFOLD,
FRONT MOUNT INTERCOOLER,
MALPASSI RISING RATE FUEL REG,
WALBRO FUEL PUMP,
EXCEDY CUSHION BUTTON CLUTCH,
K&N POD FILTER,
3'MANDREL DUMP PIPE TO CAT,
BLITZ 3' S/STEEL CAT BACK EXHAUST,
BLITZ 5' ADJUSTABLE CANNON,
18' BLACK ALLOYS,
S14 FRONT SEATS,
NEW CARPET,
B&N BODY KIT, RESPRAYED IN CUSTOM BLUE,
MOTOR WAS REBUILT 25 000Ks AGO,
ENGINE BAY HAS BEEN SEMI DETAILED AND COLOUR MATCHED,
REAR WIPER AND ELETRIC ARIAL HAVE BEEN REMOVED AND SHAVED
NOW HAS BMW STYLE ROOF MOUNTED ARIAL,
Did anyone noticed the T28 there at all? No idea wtf is that but seems like a good turbo from what John and Tristan are comparing.
dude it was a CA running a 3071 - i never mentioned an r33
you can run a 3071 on a CA, SR or RB
so to recap - we were talking about 1 turbo until you introduced the t28, and we were talking about CAs and Srs - not rb25s, lol
What about number of quotes/smileys?
Wheres the info on how to donate?
ok no i tried - there is a limit on smileys
donate? you gota msg Revhead
True and not true
EFI up the road bolted a GT47R to the side of a stock internal CA a few weeks back. It did probably 100 dyno pulls at 36psi and a handful prior to that at 48psi.
Ended up bending a rod at 516rwhp but they threw some more cast pistons in it and went to Al's dyno day the following day.
Still going at 36psi.
I've got video if anyone wants to see it
    • Sorry I didn’t explain myself properly, by free revving I meant if I just floor it, it gets to 7kish and will start to break up/not hit limiter properly, off boost I’ve driven the car until near on empty. I have a fuel pressure gauge mounted in the engine bay, holds fuel pressure consistently full tank or half tank even when revving, and no the pump sound doesn't change. all the fuel lines inside the tank are fairly new but will look into it, could that also be an issue with the lines outside the tank ?
    • Yeah maybe I got a bad batch that only lasted 6 years. Or conversely maybe I got a good batch that managed to last 6 years.    Either way I have sourced a set of OEM hub/bearing assemblies  so I keep hearing! Even from life long mechanics. Apparently this failure is unheard of…
    • I am trying to understand how that even happened to the hub... wtf
    • Hell, I'm sufficiently wary of the ZSS suspension arms, let alone something like a hub.
    • Got it back home and got started pulling the hub off and diagnose the issue. Axle was stuck after removing the 36mm nut so i used a 3 jaw puller to try and push it out and... eH5FXvJ8.mp4   spend the next few hours trying to remove the axle from the remaining hub as it was very much jammed in there when the spindle sheared off. resulting damage as below R53AIy6 - Imgur.mp4   Looks like the was already a stress fracturing in the spindle as can be seen with the darker cracked section My working theory is maybe when the pinion gear exploded last year the shock put through the hub was the initial crack. Then a few events later it finally let go. Just lucky it happened where it did and not 190km/h on the next sweeper or into the hairpin The bearing/hub assembly went in in 2019 and were non-genuine "ZSS" assemblies and no nails were harmed in the process. #BreakHubsNotNails
