http://www.skylinesaustralia.com/forums/Mt...va-t298982.html
woooooooooooah!
Oh yea. JustDave's photo for SAU Charity Cruise are up in Hot 4s issue 188 (got a small ass view of my car). Not really worth it imo. 2 page coverage + that magazine's crap too. All about cosmetic styling. Boring cbf even reading them. Just a thumbs down, the person who wrote that article on the charity cruise called an orange gtst gtr,... "Obviously this GT-R owner loved Fanta as a kid".... WTF?!?!?
Wreckers? Or if you show me exactly what bit you mean, I'll look it up on FAST for you and you can price it up new through nissan.
The black bottom section - with the clock in it. The right hand side of it was drilled through. :D
NFI, but I could possibly be convinced to buy a new M80G, if you want to put in some cash for the siren (I'd really like my boot release to work)
It was only an immobiliser that was installed, so even getting a siren won't do sweet F.A. It'll probably only cover the doors alarm wise (if they were even hooked up), not my boot and bonnet. I'm just going to save up some cash and get Chris Rogers to rip out the piece of crap that's in there and put one in properly.
Can't remember. $230 odd I think, plus about a day install (tis an epic install)
The unit (M80) is very good. I think you got ripped by the installer.
$500 for JUST an immobiliser. And a dicky turbo timer :)
Your face is a let down.
Left Ankle - 3
Right Ankle - 2
Right Leg - 1
Left Arm - 1
Right Arm - 1
For a total of 8 broken bones playing Football.
I've easily broken more than 8 finger bones. +1 eyeball
Bloody ginger kids are so fragile
+1
it's a combination of being fragile, and every bastard wanting to hit them
LOL!
or on them. Think about it
:P
Molly quinn?
:P
$500 for JUST an immobiliser. And a dicky turbo timer :D
Isn't it an M80?
and should update yaz fellaz,
HKS cam gears alredy purchased
power fc and boost contoller kit is arriving soon,
front pipes ordered if justjap,
Project Mu B-Spec brake pads arrriving soon swell,
synchros and bearing will arive by next week from japan
250awkw hopefully
nothing beats being drunk on a tuesday night loool
god i am so Fa**ed
+1 for drinking on tuesday night!
i really gotta get a better job.
Isn't it an M80?
Yep.
Remember how we were wondering wtf an M80i is? Well, it's just an immobiliser. You have to buy all the extra parts (sirens, sensors etc) and install them as well.
So I got an immobiliser, and a hole drilled in my console, for $500. :P
You know how sometimes certain things just make you want to not drive your car? This is one of them for me.
Yep.
I'd lay odds on it being the same unit as every other M80. So all u need is a siren and a bonnet switch (should be available from jaycar) and a bunch more black wire to get it to work. Do you have the instruction manual that came with it?
You could always skip on the siren and just use the horn, but thats a bit ghey
This has cheered me up slightly. Thank you kind sir!
No problem :P
we just lost our indoor football (indoor soccer to the unconverted) match 2 to 1.
they had a team of 5 plus 3 subs, we had 3 players. 40 minute game of running, our rest spot was goal keeper
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
