That is not nearly enough nuggets. You need to double your nugget intake asap. In other news our computers are down at work. Apparently they sent us an email regarding this during the week but I can't remember any so here I am at work with nothing to do and not even any internets to whore off properly. I think I'm just gunna go home...
So you've got no internets to do interweby things :)
I just lost didnt I ?
Will do, next nugget order
LOL
Do it. You know you want to
You lost the game
F*CK!
Damn your oiley hide..
What would be causing my idle to adjust a lot ? It sits on 2000 then it'll drop to 900 odd then up to 1000 down 900 up 1200 up 2000 down 1000. It's all over the show :)
Dirty or a non properly connected afm?
Maybe its just old :)
See you at the drag!
Its God's way of telling you that you should be going.
So i felt like some nuggets last night. Went to KFC, ordered my 18 nuggets in the drive through, get my box of goodness and go. When I open said box, there is no nuggets in it and instead: 4 wings >_< . Debated for a bit whether to just eat the wings, but in the end principal, and the fact i really wanted nuggets, won out so I went back. Found the manager "whas goin on here breh?". He goes off his tree at the drive though bloke (which immediately made me feel better :) ), then goes and gets me nuggets, and tells me I can keep the wings as well. Plus there was about 25 nuggets in the box, and they were all fresh. Win.
epic epic win
i love this
@Tristan: Ute may be at cooroy on monday. I'll try and arrange for it to be left at petrie, but no guarantees.
you're killing me, but i can work around it
ps like my new pic ;)
Bunta:
As for rb25 NEO into a ceffy, you should get onto Kev Rowley, send him the loom and he will make it work for your application, smity got kev to wire in his 25 for his R31. Very good guy and very cheap work cause he's a retired man. Also owns a very cool VG33 powered 120Y
Cheers Mate i will suss that out!!
What would be causing my idle to adjust a lot ? It sits on 2000 then it'll drop to 900 odd then up to 1000 down 900 up 1200 up 2000 down 1000. It's all over the show >_<
AFM related, so broken AFM/wiring or and air leak
+700
oops forgot to log Anna out
Thanks for that will investigate. If it is a AFM what's a good one to replace it with ?
Just get a PFC d'jetro and f**k the AFM off . . . lol
Edit - Or a vi-pec >_<
unless you have a aftermarket ecu use a rb20 or series 1 rb25 one for a series one or a series 2 rb25 or neo one if you have a series 2
gah i really need to remember to log Anna out
    • The speedo's can be very conservative, when my Mazda NC MX5 speedo is showing 118kph, the GPS, and a calibrated radar.... cop mate.....hits me at around 110kph +/- 1 or 2 kph, and that is on a 215/45 17, stock tyres size is 205/45 17 as well, so weirdly conservative with stock tyre size When my Commodore speedo red 116kph GPS had me at 110kph After doing some offset and clearance measurements to see what can fit the NC on 17x8 +40, without guard rolling or rubbing anything at my current ride height, I've decided that when my tyres are toast, I'm going to fit 225/45 17 and see where that gets me IRT actual speed of my speedo and GPS/radar From the online calculator I should be still be doing around 5kph under an actual 110kph when the speedo is showing 110kph My ADHD requires that when I'm doing 110kph on the speedo, that the actual road speed is actually really close to that, and not alot slower And going from 205 to 225 still keeps the car within the %/mm allowable in the NSW vehicle rules and regulations, which is nice, as long as I'm looking at the latest version that is.....LOL https://www.nsw.gov.au/sites/default/files/2021-02/RMS-13.464-Light-vehicle-modifications-Vehicle-Standards-Information-No-6-November-2013.pdf
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
