bahahahaha
that explains the 4 lanes....
go on john - make reference to it - with a pic from the first fast and furious hahahahha
nah, it wasn't his thread. He was just sticking up for the other guy that you told to f*ck off to another forum. Would have been good if he started the thread though.
ooh i see
i remmeber how he went on his own tangent for ages hahahaha
ok, so... I might have thrown another log on the fire :)
and that is????
he used to drive a 4 door 34 auto - but he sold it - so thats a lack of log :)
Erm... xmas party and start of holiday? lol.
fair call bro :D
P.S. Tris: Wednesday = next test starts to help keep me occupied for my final 3 days at work :)
ah the old cricket
brilliant
I see lots of lurkers
:thumbsup:
yoo hooo!
    • I'll get one of these also just for giggles
    • I bought 6 new spark plugs to compare readings. They will be here tomorrow and ill see if meter is far off if it all. I know one is at least reading 0 so its best replace all anyway if one is bad, from experience. I still have to test the harness just to be sure its not a double issue and I waste my time haha-the old plugs are iridium I always thought those lasted more than 50,000 km.
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
