HAHA yeah I recon we get away with a fair bit aye
We're not all c*nts :cool:
This obviously turned into a whore thread so personally I treat it like whoretown. Actually you farkers whore this thread more than the rest of the state whores the 'real' whoretown lol.
TBH this thread should really merge with whoretown...
We're not all c*nts :)
Hahaha
Nah I like all the admin on this forum, Its good how you get involved in the never ending whoring and ridicules/awesome convos . . . lol
*nods*
Hahaha. Considering we've even got guys down the coast whoring here!
You knw it brotha from anotha :D
P.S - Gold Coast FTW :P
NNNOOOOOOO! No merger! This thread is epic win
*nods*
-1
+1
I just smashed my omnia HD on the tiles, FML i really hope i remembered to get insurence
Massive LOL
Oh noes, ouch!!
I might have a spare phone lying around, it'd be nothing flash but if you're stuck without one you're welcome to it
Oh noooo that sucks
PS: Dan, yes its a picture of "I see what you did there"
HAHAHA
Work pc = epic fail
Yeah read about that earlier, deceitful pricks.
The thing they don't understand (or care about) is that it's not about people wanting to look at kiddie porn or bomb instructions or whatever... it's about some pen-pusher pretending to be our mums, deciding what we can and can't see.
IMHO...
If you're under 18, it's your parents' responsibility
If you're over 18, you're an adult and can make your own choices
If you *do* look up something illegal, then you should be punished accordingly
Farken left wing evangelists, get back in your Prius, hug a tree, pat yourselves on the back and GFTO of our internets!
Thats exactly it Revhead. I have no desire to look at CP or bomb instructions, but you can guarantee there will be scope creep with something like this. Before long, everything the gov't doesn't like will be censored.
In my opinion, the government is spending FAR too much time and money trying to do parents' jobs for them, which in turn makes parents less responsible, and thus worse parents, so the gov't tries to do more, etc.
We are rapidly coming a police state where the gov't decides everything we do, and I don't like it.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
