Thristian: SLACKA! I thought you're suppose to be helping Dave out today?
yeh im a pretty shitty mate - got way way way too blind friday night
Hahahaha yes I have seen that. But it's just as awesome every time I watch it!
I imagine you'd also have seen Chad Vader, Jase?
No mate don't think I have. Thanks for giving me something to do this day at work. :banana:
dear martin + dan
<3 astro
dear martin + dan (part 2)
<3 tristan
Dear Tristan,
Do 5 stud conversion so I can have your hubs.
<3
Colin
Dear Tristan,
<3
Colin
fund it and you have a deal - my 4 stud comes with brand new pads and rotors also :)
lol how is the 180 going neways?
edit:
Awe <3
I wanna know how the engine swaps going!
motor is out
cam across some dramas along the way - as expected, so now i need to grab some parts and get them to me hopefully before xmas - and then the new sr goes in :)
huge thanks to arif, dave and rhyso :(
    • I'll get one of these also just for giggles
    • I bought 6 new spark plugs to compare readings. They will be here tomorrow and ill see if meter is far off if it all. I know one is at least reading 0 so its best replace all anyway if one is bad, from experience. I still have to test the harness just to be sure its not a double issue and I waste my time haha-the old plugs are iridium I always thought those lasted more than 50,000 km.
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
