Thristian: SLACKA! I thought you're suppose to be helping Dave out today?
yeh im a pretty shitty mate - got way way way too blind friday night
Hahahaha yes I have seen that. But it's just as awesome every time I watch it!
I imagine you'd also have seen Chad Vader, Jase?
No mate don't think I have. Thanks for giving me something to do this day at work. :banana:
dear martin + dan
<3 astro
dear martin + dan (part 2)
<3 tristan
Dear Tristan,
Do 5 stud conversion so I can have your hubs.
<3
Colin
Dear Tristan,
<3
Colin
fund it and you have a deal - my 4 stud comes with brand new pads and rotors also :)
lol how is the 180 going neways?
edit:
Awe <3
I wanna know how the engine swaps going!
motor is out
cam across some dramas along the way - as expected, so now i need to grab some parts and get them to me hopefully before xmas - and then the new sr goes in :)
huge thanks to arif, dave and rhyso :(
    • Resizing injectors in Nistune can be done a couple of ways, and there are a couple of ways that you can make a mess of it. The tuner needs to be really aware of the effects of whichever approach he uses (either K, or TIM). They are both easy enough to "get the injector size right" to run the engine. But little details like old start enrichment and hot start are affected differently, depending on which boxes you check.
    • Pretty safe to say almost everyone that has tuned their own car has experienced this issue. The difference being that we have our laptop in the car and when it happens, it's literally 10 seconds of tuning to sort it.  Would you be happy to plug in your laptop and sort this yourself? It is a very simple process and there is no risk of harming your engine (if you are worried about that).
    • Yeah thats the next step now, either they wil or i will take out for a drive to work and go straight their after work and see is we get the same issues 🤞  thought i try my luck here too, never know someone else might have had the same issue but thanks for the reply
    • Basically your tuner needs to drive it for the 30 min (or whatever) to create the same conditions then check the ECU settings and sensors at that time. They may not be excited to because that takes them 30 min rather than just opening the bonnet and seeing the problem straight away.... Hot start is generally not as tricky as cold start, but there would be a table for fuel enrichment vs coolant temp as a starting point
    • Yeah, they all cant say anything for sure as everything is working fine . Said unable to find an issue untill it stops again. Could mist likely be CAS wiring or IAS valve issue but again not 100%
