Hi im here to not contrubute to SAU
How was everyones festive season! To sum up my holidays, I am now offically PS3 addicted, can no longer drink Glenfiddich (nearly vomited just saying it), Dan now has a very tidy and ordered workshop and the gympie skidpan now has a new water pipe that is not half full of mud so all corners of the pan get wet! And getting i a pool after 8 hours of shovelling and jackhammering is maybe the greatest thing you will ever experience.
Feels like I have actually worked harder this holidays than i ever did at work!
John (Yaface)
Budget on a rebuild with the GTR, Mine was as well looked after as any and it spun a bearing just because it was old and worn out, you might get lucky but the odds are you wont and it would be a shame to break it then not be able to afford to fix it. Other things to look out for are attessa systems that are clogged up and barely work, get Dan to flush it and give it the treatment he gave mine and it will trasform the car, all of a sudden the slow attessa lable that R32 GTRs get lumped with seems a little misguided. Cracked rotors are somthing to look out for as they really hammer the front brakes and the syncro for 3rd gear is often fubar and a sign that it has copped some abuse in a past life. Look for worn upper control arm bushes chances are any one you come across these will be on the way out so budget on getting those fixed. they are also pretty good at getting rust up under the rear guards and also check under the boot carpet as they can leak around the tail lights and fill the spare wheel well with water
As for ownership....they are an awesome car i spent a fortune on my r32 with a 25 and was never happy with it. First drive of the GTR just felt so much better as it had a little more power, better powerband and the ability to put it to the road anytime i wanted. The down side of ownership is complexity, any work you do on it (except changing sparkplugs :P ) will take a lot longer! They also use tonnes more fuel, at 315rwkw is was getting 550km mixed driving from a tank in my GTST...in the GTR it would have been lucky to get 400
consider yourself invited tristan i need some one to help on 2 missions in modern warfare 2 as they wont let you do it single player!
im shit - but sounds good hahaha
while i think of it - you and anna wouldnt have a spare sr bov would you?
thats ok im not great either lol
we do actually!
YOU DO?!
zomg buttsecks?!
consider it mine - when can i come get it hahaha
ps dont tell me its atmo...
hey astroboi, did you get the combine harvester running yet?
sheared the head of a flywheel bolt at around 5:15 last night - so had to wait til today to get a new one
so long story short - no
however the fact that there is a nismo twin plate going in makes it ok to wait a day :P
coolies. So whats the current ETH (Estimated Time to Harvesting)?
tonight we're hopeful to get the motor and box back in
and i <3 ETH :P
just trying to organise a modplate today for the lack of rear seats and ze fixed back
and trying to get the bov off andy :)
Tristan: it is stock, I will go home and dig it out, make sure its ok, then you can come get it anytime
John: It shouldnt cost a lot, the thing that stops it working is a paper filter that breaks down and clogs the line, you guys seem cluey enough so perhaps a few of you could do it, you just have to take apart the whole system, lines, pumps ect get the sludge out then put it all back and bleed the system as per the manual. after you do it you will notice all of a sudden the tourqe split needle is much more active!
Hit me up if you need someone to do the mod plate. I know a guy who will mod plate anything
Cool, thanks for the info!
does the filter need to be replaced? if so, is there anywhere to buy them from?
It may still be a Dan job though I'm thinking... that seems like a lot of poking around in a system I'm not familiar with...
very interesting,
what sort of time frame/cost?
ps loved the love you gave my thread :P
Never done this before but um.... FIRST...
Scrapage and I think it's fkd up and out of alignment completly....
On another note, this question goes out to colin mcranga and anybody in general I guess but besides the obvious are there any known common faults on 32 gtr's and ownership of one. I'm talkin about only a lightly modified one here... (obvious problems being the engine ready to fkn die on me and a fkd gearbox/clutch)
Huh? 32? What happen to the 34?
    • Sorry I didn’t explain myself properly, by free revving I meant if I just floor it, it gets to 7kish and will start to break up/not hit limiter properly, off boost I’ve driven the car until near on empty. I have a fuel pressure gauge mounted in the engine bay, holds fuel pressure consistently full tank or half tank even when revving, and no the pump sound doesn't change. all the fuel lines inside the tank are fairly new but will look into it, could that also be an issue with the lines outside the tank ?
    • Yeah maybe I got a bad batch that only lasted 6 years. Or conversely maybe I got a good batch that managed to last 6 years.    Either way I have sourced a set of OEM hub/bearing assemblies  so I keep hearing! Even from life long mechanics. Apparently this failure is unheard of…
    • I am trying to understand how that even happened to the hub... wtf
    • Hell, I'm sufficiently wary of the ZSS suspension arms, let alone something like a hub.
    • Got it back home and got started pulling the hub off and diagnose the issue. Axle was stuck after removing the 36mm nut so i used a 3 jaw puller to try and push it out and... eH5FXvJ8.mp4   spend the next few hours trying to remove the axle from the remaining hub as it was very much jammed in there when the spindle sheared off. resulting damage as below R53AIy6 - Imgur.mp4   Looks like the was already a stress fracturing in the spindle as can be seen with the darker cracked section My working theory is maybe when the pinion gear exploded last year the shock put through the hub was the initial crack. Then a few events later it finally let go. Just lucky it happened where it did and not 190km/h on the next sweeper or into the hairpin The bearing/hub assembly went in in 2019 and were non-genuine "ZSS" assemblies and no nails were harmed in the process. #BreakHubsNotNails
