Is that the 25/30?
Never heard of that. Maybe if the chrome gets cracked and it is exposed to water could be a problem
Could be my shootin car eh?
Back in work today. 223 new emails 50 new aconexs and 173 cc'ed aconexs. This day is a write off lol.
Aren't car shells the new water features ? I've been told they look great in your front yard.
Does REDSUN still get online much???
I think I just found his number plates. lol
http://www.boostcruising.com/forums/index....howtopic=498387
Pretty sure he still lurks occasionally
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
    • Does anyone on here know which wire on the GTT triple gauge pod harness is for the oil temp gauge? my sensor works fine but I upgraded the gauges to DEFI advance. And if I can simply piggyback off the oem oil temp wire to the Defi oil temp sensor wire that would make life so much easier.
    • Even face her a wash now that’s it worth more than my house
    • This was what I was invisioning, or Pete cutting a beer can up and hose clamping it around the catch can! Ha ha ha
