I remember saying that once....right before i spent 30k on my other 32 lol
haha one day bro one day, when i have enough cash saved up,my plans are to buy a R34 GTR V-Spec II NUR and then modify the R33 upto about 350awkw,
if i earnt this money i wouldnt be as sad as i am now, the sad reality is that i am 18, unemployed and still have another 2 years of uni to go,
Martin, no pain at all! It might not even be electrical current but you do have to shand on metal plates with no shoes on! we got ours from the good guys for like $100
Haha, yeah I was joking. But i've just read up on it, it is indeed an electrical current that goes up one leg and down the other. Thats right past the fun zone! :)
There some for ~$30 on ebay, they should do the trick doesn't need to be HK.
PS NPC twin > Nismo ha ha
Jim Berry Clutch FTW!
*Flamesuit on
Edited by Smity42
nah man there is sum special equipment u need to open the forks up on the gearbox, only a cuple of guys have it in qld, and the guy Dan at ERD uses, just got back today from holidays, so gearbox work will start today, the rest is all nearly done,
probably wil be monday or tuesday next week if everythin goes according to schedule and theres no hicups etc.
brake pads are being put in today, machining rotors etc will be finished today as well i think,
power fc is in, engine check light was on so Dans troubleshooting that,
front pipes and high flow cat need to be put in, then the full service needs to be done all fluids etc,
cam gears and timing belt and water pump and a new battery wil also be put in,
thats all i can think off,
after that its going to be off to EFI for dyno tuning and then on the highway home to St. Lucia
out of all of that all that was needed was one synchro replacement, and full service and brake pads and the clutch which i found out about today.
ha ha good old Jim Berry
We threw out a lot of old pressure plates cleaning up Dans the other day....should have taken them to Jim he could have pivot modified them and charged 1200 for em! :)
hey bro, i would love to get the nismo twin plate, heard awesome things about them, but the sad truth is i have now spent nearly 7 grand on the car and thats not including the clutch, it hurts me because all i needed to spend was about 3 or max 4 grand, the rest was all things i wanted not things i needed, Dan recommended the heavy duty clutch from NPC, the one that replaces the stock clutch, he said it would be strong enough for upto 280awkw,i dont know if it will be able to handle launches etc
and im calling it quits for now, once this stuff is done, all im gona do is service it, ive spent way too much money on things that werent needed and that money could have been spent elsewhere,
-FML-
from the man himself adam...
NPC7056HD -- 240kw
NPC7056HDB - 300kw
Bigmouth Street - 300kw
Bigmouth Track - 400kw
NPC Track TWIN - + 1000kw
NPC Street TWIN - + 750kw sprung or cushion (cushion is solid centre plates)
NSK7056HD - 240kw
where HD = heavy duty
HDB = heavy duty button
and I don't think you should do limiter launches on the one you're talking about either.
Edited by jaxt
NPC twin for 2k+? Thats in the range of the Nismo twin coppermix (unless you got hit for tax when you import it or get it locally, which is around 3.5k). But if Mark uses that on his 7sec car, it cant be bad at all. DO IT!
NPC7056HD -- 240kw
NPC7056HDB - 300kw
NSK7056HD - 240kw
yeh, as long as its a bit stronger than stock im happy, ive only done a launch once at 5K rpm and thats it, i never need to launch as i dont drag etc just a street car so should be good enough i hope.
NPC7056HD -- 240kw
NPC7056HDB - 300kw
NSK7056HD - 240kw
*nods*
Those good for 300kw would be sufficient for normal driving but probably not limit launches. I'll get a comfortable twin if I'm ever changing the clutch for sure (either Nismo or that NPC if its really gentle on my foot).
i think my car will make around 230 to 250awkw after everythin is done, so clutch is good enough for the job
f**king woot, i changed some settings and my quote button is back!
Should be more than enough for your car given it is on street duties
nismo twins are rated at like 500hp, the ine on my car is 1000hp, and you only have to loook at the construction to see why
http://www.nengun.com/nismo/super-coppermi...in-plate-clutch
600ps... which i think its close to 600hp too. But my justification for that is comfortability. Everytime I read about someone's review on them, they're bound to mention how comfortable it feels comparing to other twins. Although NPC seems to be better value for money, but if I dont ever need that kinda rating, I'll go with whichever that feels more comfortable.
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
