man sheesh you should stop drinking too
you + me watching the shorty shorts, doing the wash which was very nice and i said it's like watching a fish tank the only difference is you dont have to feed them :rofl:
haha I either didn't hear you or forgot.
i would have fed them something though ;)
W00t, relisted with more photos and even more arrogant text
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...em=160393158666
HAHA man thats tha best item description/spiel ive read . . . EVA
They aren't proper semi slicks dude. The ones brandon listed aren't slicks, they are semi slicks with propoer R compound
RS-Rs, KU36s, are just really soft road tyres
Hmmmm
Watching motorway patrol last night.
Two losers both proudly announced that cutting you springs improves your handling, lol what gimps. Buy some coilovers cheap skates.
Morning all.
Morning all.
Morning.
Side note : How many tristan's do we have now ? 11ty ?
colin's sister :rofl:
Axe
+1
maybe we could meet in the middle martin!
In
Skins wants in!..
theres always room for more when it comes to colins sister!
Gooch
TPG have smashed through my interwebs install today, its now just in telstras hands for the connection, and that normally only takes a few days ;) .
Win.
Found out why my internets is taking so long to be installed. The cheapest telstra plan won't allow you to get internet or any other services through another company lol. Gay. Have to pay another $8 for teh intertubes.
Morning all.
Clearly you know nothing about suspennshun. Cutting springs definitely improves your handling and the cost vs benefit over coil overs makes it a clear winner.
lol
Ahh yep. I could have told you that :rofl:
Cutting springs if fking dodgy. Yeah if you take like, 1 coil off, it will handle better. Untill the springs unseat and cause your car to do a barrel roll. Or you cut them unevenly. Or one of the other 11ty billion things that can go wrong.
Replacement springs are cheap...
Ahh yep. I could have told you that ;)
Your sarcasm meter is broken :rofl:
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
