f**k this thread moves faster then ever before - and even without my contributions
been cruising in the 180 today :)
and working on the 32 :P
I thought you sold the 32 ?
Correction. Swapped.
That 32 he's working on is probably Dave's.
Dave/Tristan: Hey you guys keen for dinner tonight after you're done working on the car? I can drive up and pick the poor bugger Adam up as well.
daves 32 mang
i wish i was that loaded :)
im off to workiesss
holla holla
OIC
Your sarcasm meter is broken :)
Apparently it is...
*Brandon: IN TA COOLAH. NOT Oil cooler. It does the green stuff, not the brown stuff.
Actually, there's no green stuff in it. It just cools the invisible stuff (air)
Dan and I think we spotted bunta and spAnna in the sil80 this afternoon on lutwych rd. We were in the dirty XF + trailer both loaded up with furniture.
...that made me think "wtf" and I had to google to research something... I never actually realised front mounts were air only. I thought they (auto intercoolers) were all air-to-water coolers.
my bad
evenin all. every time I visit the west, there's a bloody speed camera on milton rd or western fwy.
are they there almost every day or am I just unlucky?
late afternoon, the van parked opp the old milton tennis centre was really well hidden.
it's there 9 times out of 10
lol ill correct you - u have no idea
and yes of course it was daves 32, which is looking sex
German club last night was disappointing. Got there a bit after nine, got told the kitchen was shut, even though the website says its open till 10. They did cook us some mean schnitzels though. Then last drinks was called at like 9:30, and we were kicked out at 10 :happy:
Just means we have to go back, earlier next time :cool:
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
