Yeah thats what I recon . . . Now I jus gota get rid of my wheels
Just keep a look out for them on forums. Maybe import monster or ebay?
+1 for TE37. Looks great + easier to clean that multis. Man your 34 is really a money pit now! Just got new rims not long ago and now you're changing again... Hahaha.
PS: you do realise for TE37s to have those dish size, you'll needa get 10.5" yah?
OMFG :thumbsup:;):):):O
That is all . . .
The size of the rims remind me of those on Hate Tax's. You cant even see the rubber. Looks weird to me but nice dish.
anyone interested in going down for top gear live?
lowballers be warned: it won't be cheap
I was thinking of it. Should be good. Where you going to stay and stuff?
How was everymangs weekend ?
I was thinking probably not staying, just fly down for the day
Have you looked into the package deals ? See the show stay the night then see the top gear car museum
i didn't know there was a car museum?
If its the same gay shit they had last year, it's not worth it. But I wouldn't have called that a museum.
I'll look into it...
Dunno mate. Just saw it on the ticketek website
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
