If that was my car and I sold her I'd be tearing up right now.... Your current one is still pretty fkn nice breh
it was pretty nice, but caused me a lot of headaches, the current one was faster in every way and doing it easier so in the long run i think i will like it more
I came... :(
How come the builds taking a while? Parts on order and shit??
Dan had a lot of engines to build, i think when i put it in i was like 10th in line or somthing
Oh gay. Yeh the bastard gets pretty busy though. He should clone himself....thrice
fixed back and 2 seater
cuz im hektik worried about extra weight bro
ahhh i see! i love hatch action with the sil80....fold that seat down and you can fit all sorts of stuff in there that the skyline had no hope of fitting!
and i want nismohs approval at my concern for pointless extra weight
Nizmoh is pointless extra weight! BAZINGA
SR redline is 7500, alright ill start a little more tehehe
ps martin i think im a real contender to challenge your epic dose :P - she doses nicely, especially considering the boost is set on 4psi
in for dose challenge, we have a BOV but it doesnt seem to open ever
Mine doesn't open ever either:
flutterz
i get dose reversing into the garage, its pretty hectic
Everyone loves good flutterz. Even those RTA add chicks :(
thats when you know you're baller
sil80 the GTR flutters when i sit in it and make engine sounds errrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrmmmmmmmmmmmmmm sttututututututututututu
OMG even the word "dose" is ghey
+1
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
