On a serious note, my car got taken back today to get the front bar repaired properly....for the 3rd time. If anyone is free next week, pm me as we may have ourselves a good ol fashioned gathering with pitchforks and torches to put some panel repairers back in line
eeeps!
.9 bar makes me sad in the pants
Lol, be happy with what you got. I'm only running 12psi as of last friday....was 7 before :banana: ....think i might go jump now
Yeah, divide by zero always awesome.
Currently on hold with tpg. Awesome.
Good luck with that dude. Worse call centre ever.... You'll wait 30mins...sometimes get hung up on when you finally get through and sometimes even when you call through it cuts out straight away cos they can't take any calls in the que even....lame
TPG has some of the best deals, but i have to admit the crappiest customer service department ever, my housemate called them the day he was leavin to get our internet disconected, and they put us on hold for 45 mins, everytime we had to call them we were put on hold for atleast 20 mins
but theyr new plans are very good in terms of what you get for what you pay,
im gona go with the adsl2+ 120GB (60+60) plan once i move in to the new place, its shaped to 512K which is way better than my previous plan which was 64K, even google would take time to load at that speed lol
response and fuel economy over powa will be tuned at 0.9 bar,
EPIC EPIC EPIC EPIC EPIC EPIC EPIC EPIC FAIL
as does fuel economy on a gtr
+ 1
Save yourself the trouble and buy an Excel with a loud exhaust. Then the GTR can go to a nice loving home and be driven like she deserves.
Chalk has mad food! I'll never go there for a drink though. I'd need to remove my shoes, lose some teeth and fk my sister to fit in with the crowd there on a fri/sat night
I've seen the kind of people that go there. They'll never be getting my business.
Why wouldn't it? Does google have some weird load time exclusions, or exceptions?
Google always took time to load on dial up at 56K so I imagine 64K would be almost the same... Images and text... it's gonna take a second or two to load...
:banana:
lol everyone wants different things out of thier cars,my cars street driven and response and fuel economy is more important to me then having 250kw is, il tune it the way i want since i am forking out so much on it, with stock turbos im quite happy with 0.9 bar of boost.
afternoon
i see another day of solid whoring in here. to save me reading all the crap, did I miss much?
well, I just read through it all and posted to catch up... So I can safely say no.
From now on I'm going to call you Brandon 2.0
in all seriousness trying to save money on fuel and other assorted things and having a GTR is a bit like wanking with sandpaper it can be done but it isnt the right way and the end result wont be as enjoyable as it should have been
This is true unless you're german, in which case this is considered to be normal and sexually stimulating.....
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
