Yeah... I really gotta stop giving people that much credit huh? I'm starting to get soft in my old age.
Yep
one for me:
and one for Martin:
I approve!
we should buy these planes and do Top Gun style war games :cool:
I like it. But while I'm sure we could pick up an ol' F14 or two (possibly from the aircraft graveyard or Iran), I think we would struggle to source any raptors...
*edited* because I remembered too late that it was F14s that Martin likes... not F15s.
Solid effort!
I can't help it man seriously. I'm a chronic procrastinator. I procrastinate procrastinating....
Join the club :)
F*CKING LOL
Morning yo :(
Morning mang
So just incase anyones interested Ive made my desicion regarding the new rims :cool:
And the winner is ....... Bronze TE37 in 18x9.5 & 18x10.5 .... now I jus gotta get home an figure out wat o/s Is gona be best fit :(
I told you he's a sl*t
'tis true
Where the flip is everyone ? ? ? Or am I too early . . . again ;)
There seems to be a few lurkers, but yeah too early for most...
So just incase anyones interested Ive made my desicion regarding the new rims :)
And the winner is ....... Bronze TE37 in 18x9.5 & 18x10.5 .... now I jus gotta get home an figure out wat o/s Is gona be best fit :cool:
0 or less :(
Someone on the forum is selling them... check the for sale section I think. Great minds think alike. Plus the lesser spoke and bronze will make them virtually maintenance free.
Oh really ? ? ?
Quick find them for me :(
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
    • This. The R34 handbrake icon DOES come up when the brake fluid level is low. You might be sitting right on that threshhold. I have been down this diagnosis path and this was the solution (and it was pretty much as full as your picture is to begin with).
