true. still shoulda held out for a 33 though :D
I like 32's more than 33's - Especially if they AWD
Only down side I guess is the RB20, but then again that can be changed
yeah well when it's rb20 and awd isn't working... :D
and no air con
and rooted immobiliser that I got ripped off for and it's not even installed properly
and tyres are 20 years old and dangerous as fuck
and rear rims are warped
and afm lasted 4 weeks
and reverse switch rooted
*sigh*
poh wei soon
Lol
and no air con
*sigh*
Chin up ol' chap, at least it runs :D
and no air con
and tyres are 20 years old and dangerous as f**k
*sigh*
f**k man that does suck . . . Let me knw if you need any help with anything aye
and no air con
*sigh*
Well if you've got it for a good price then just gotta slowly fix them up. But then again... 20yr old tyres sound ridicules, hows that gonna pass rwc or even compliance. Wasn't that like a fresh/recent import?
and no air con
*sigh*
sounds like the way to fix it is with a gun
:D
I think he maybe exaggerating a little bit about the 20yo tyres bro :D
thanks man, none of it is really anything I feel like attacking myself. I think I just need to save up some coin and get it a top to toe engine/electrical service
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
