i have no idea what ur talking about..
oh wait, you don't have thristan's 32 anymore do you?
FFFFUUU
pun fail
omg what hachi?
the hachirusto that you're preparing for epic mountain pass cliff face launches.
bradon did !
i posted to try and keep it going and where was u i passed the ball to you but u was no where to be seen!??
bish!
I was going round on the overlap but you didn't see me. Miscommunication.
omg what hachi?
:rolleyes:
getting the shits with brake upgrades.. Wilwood all the way f**kers!
AP? I like APs.
This one.
well well the cats out of the bag..
tahnks f**kers!!
anyways its nearly done..
ordred the steering wheel and rails and few bits and pieces
half way installing guages.. running as is for awhile while i build up another engine to put in..
Discussing the zombie apocalypse with a mate the other day and I have my plan all figured out. f**k staying in some random house were all the zombies can swarm outside. Have you have seen a zombie swim? I'm stealing the biggest f**king yacht I can when the zombies are coming. Then just return to land for killing zombies, food, water, porn, essentials like that.
F_ck that. Just set them all on fire then when there is just bones left build a big ass xylophone. :rolleyes:
also another good option for safety measures. Moat around house. Oil on top of water and set it on fire. Then the zombies can drown in the fiery water.
But how do you get the bones to make the xylophone ?
    • Today, I'm a Breville BES920 tech, new triac board and new 3x way solenoid. Had overheating issues, home RCD tripping when it got warm, and the boiler stayed on when the machine was shut off. Also, usually 3x way solenoid chatter, this is the 3rd time I'm replacing it. Mind you, this machine is 9 year old and send it every day doing at minimum 3x double shots. When the in laws come over to took after my daughter, it will easily see 6x double shots in a single day. Tried to be somewhat compliant, crimped and then used a screw connector over the top. Would have preferred to use heat shrinks.   After all that, turns out all the overheating has damaged the o-rings to the steam tap as well. Ordered new ones, coming soon.
    • Still got it- First time checking sau in a while ahhaha
    • I don't know about that. I can hoon my R32 around - hard launches, high lateral Gs - with <<1/4 tank without any such shenanigans. This with the previous 040 and the current GSS342. I would suspect a fuel line problem. One of the hoses associated with the top of the tank perhaps.
    • This is amazing. Love that you’re giving the boys an intro to cars and off the screens. They probably have an insta for the car and build posts on TikTok for their mates.
    • It is.  Your car works fine with the tank full. If you drive like a Nana it works fine.  You give it a boot full with half a fuel tank, you get surge.  It 100% is a fuel surge issue. Maybe have a look at installing a Hydramat if you don't want to install a surge tank.  https://www.holley.com/products/fuel_systems/hydramat/
