Yeah so you guys die in a blaze of glory and I survive and repopulate the earth with rangas? RED POWA!
d00d i just said u would be getting owned by zombie crows!
RED ZOMBIE RANGA POWA!
nah I never agreed with the blaze of glory that Tas mentioned. He can blow himself up if he wants. I'm all about the repopulation :D
im keen for the zombie secks
sif owned by f**king crows. Go far enough away from land and birds aren't a problem anyway.
seen dawn of the dead? they tried your plan and got f**ked up
that was only because they didn't take enough gas and drifted to some random island.
if they had have been smart about it it could have worked.
you really only need to go out a little way and drop anchor. then pick them off one by one with a sniper rifle :D
yer, im with colin on this, i'm crimin' an oil rig to chill in, except i want a speed boat to get from shore to rig, think of the amount of ammo you will waste through in a full day killing, i know in an afternoon/evening of shooting roo's (with a permit) i ran through 20 rounds just taking it easy. You will need to have somewhere safe to relax while reloading all that ammo. Plus oil rigs are awesome town, only a small crew on them so not too difficult to take over.
Rifles eh? hopefully this time next month my paperwork will be lodged so i can get one
Would take a fair bit actually, boats rock something shocking, need stable ground to take them out over even 50 metres
I'm in for the slaughter, but how long you think it will last? I could go for a couple days full on, then back to the rig for party and resupply
Dibs on the Chevy at Tas' workshop in the event of zombie apocalypse
I'll be working out a way to mount a machine gun in the back of the XF quick smart. Whos with me?
I'll help by getting molly knocked up as many times as possible :D
We've already established, house at Petrie is zombie-proof.
I'm disappointed dan :P thought you would have been in for the slaughter
+1
    • I did basically the same procedure on a ZF6HP but the reason to pull the valve body is to replace the seals between the valve body and the transmission which are notorious for leaking pressure with age causing poor shifting and burning out the clutches. If you just wanted to exchange all the fluid you should be able to undo one of the transmission cooler return lines to drain into a bucket while using the pressure filler to keep it topped off.
    • The title should have posted "EFR7670 exhaust housing selection RB26" I can seem to edit thr title on my Android.
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
