Yeah so you guys die in a blaze of glory and I survive and repopulate the earth with rangas? RED POWA!
d00d i just said u would be getting owned by zombie crows!
RED ZOMBIE RANGA POWA!
nah I never agreed with the blaze of glory that Tas mentioned. He can blow himself up if he wants. I'm all about the repopulation :D
im keen for the zombie secks
sif owned by f**king crows. Go far enough away from land and birds aren't a problem anyway.
seen dawn of the dead? they tried your plan and got f**ked up
that was only because they didn't take enough gas and drifted to some random island.
if they had have been smart about it it could have worked.
you really only need to go out a little way and drop anchor. then pick them off one by one with a sniper rifle :D
yer, im with colin on this, i'm crimin' an oil rig to chill in, except i want a speed boat to get from shore to rig, think of the amount of ammo you will waste through in a full day killing, i know in an afternoon/evening of shooting roo's (with a permit) i ran through 20 rounds just taking it easy. You will need to have somewhere safe to relax while reloading all that ammo. Plus oil rigs are awesome town, only a small crew on them so not too difficult to take over.
Rifles eh? hopefully this time next month my paperwork will be lodged so i can get one
Would take a fair bit actually, boats rock something shocking, need stable ground to take them out over even 50 metres
I'm in for the slaughter, but how long you think it will last? I could go for a couple days full on, then back to the rig for party and resupply
Dibs on the Chevy at Tas' workshop in the event of zombie apocalypse
I'll be working out a way to mount a machine gun in the back of the XF quick smart. Whos with me?
I'll help by getting molly knocked up as many times as possible :D
We've already established, house at Petrie is zombie-proof.
I'm disappointed dan :P thought you would have been in for the slaughter
+1
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
