But if they'd not landed on earth in the 80s he wouldn't have been transported back to the 70s in the first place. So bug #1
actually it was during a spacebridge trip gone wrong on cybertron.
What kind?
C3
Remember those warning signs have to account for what is a safe speed for ANY car taking that corner (think ford laser). Double it and add 10 :thumbsup:
I would love to see you going in that particular corner at 130km/h Martin. And just that one corner.
Second - Adam complained too remember?
He said something along the lines of "My heart is beating so fast after that mountain run. I've decided I don't like corners"
Must be something about owning a 33GTR and being scared of actually driving.
The only thing I'm complaining about is the bug and petrol. I enjoyed the drive throughout the whole run.
this is my old corvette that I had before I got the S14 and the ceffy.
:thumbsup:
Sounds like a challenge :thumbsup:
before which, he is a beetle.
I just had a thought... are we talking about the same thing? The GI JOE vs Transformers comic mini series? The one that Bumblee dies in? Because if we're not, that could explain a lot!
It's a rule of thumb, it doesn't always work. But ask Tristan how quickly I dissapeared on tuesday night ;)
Good to hear! I got over complaining about petrol AGES ago. I just accept it now :(
But that would be speeding, and John would cry :thumbsup:
Johns always whinging about something anyway :thumbsup:
Good to hear! I got over complaining about petrol AGES ago. I just accept it now :thumbsup:
I suppose thats something easy but the bug bit... I dont think I'll ever be ok with it unfortunately. Maybe day runs would be better but then again, it wouldnt be as fun since you can see everything.
    • Sorry I didn’t explain myself properly, by free revving I meant if I just floor it, it gets to 7kish and will start to break up/not hit limiter properly, off boost I’ve driven the car until near on empty. I have a fuel pressure gauge mounted in the engine bay, holds fuel pressure consistently full tank or half tank even when revving, and no the pump sound doesn't change. all the fuel lines inside the tank are fairly new but will look into it, could that also be an issue with the lines outside the tank ?
    • Yeah maybe I got a bad batch that only lasted 6 years. Or conversely maybe I got a good batch that managed to last 6 years.    Either way I have sourced a set of OEM hub/bearing assemblies  so I keep hearing! Even from life long mechanics. Apparently this failure is unheard of…
    • I am trying to understand how that even happened to the hub... wtf
    • Hell, I'm sufficiently wary of the ZSS suspension arms, let alone something like a hub.
    • Got it back home and got started pulling the hub off and diagnose the issue. Axle was stuck after removing the 36mm nut so i used a 3 jaw puller to try and push it out and... eH5FXvJ8.mp4   spend the next few hours trying to remove the axle from the remaining hub as it was very much jammed in there when the spindle sheared off. resulting damage as below R53AIy6 - Imgur.mp4   Looks like the was already a stress fracturing in the spindle as can be seen with the darker cracked section My working theory is maybe when the pinion gear exploded last year the shock put through the hub was the initial crack. Then a few events later it finally let go. Just lucky it happened where it did and not 190km/h on the next sweeper or into the hairpin The bearing/hub assembly went in in 2019 and were non-genuine "ZSS" assemblies and no nails were harmed in the process. #BreakHubsNotNails
