I think the yeah me was meant to mean that he convinced himself not to buy your car :P
Pearl at Circle on Cavill. Sunday at 11?
I’m not used to this cut price education with minimal information being typed
Goldy, grr. The wide blows my smart car around too much :cool:
Use my tax money to sue me for slander or something
Ok :P
I think the yeah me was meant to mean that he convinced himself not to buy your car :cool:
Hole in one :P
Edited by Isola
run a centre muffler then?
yeeh looking into it hey - the zorst sits so f**king low, the bend just before it turns up into the cannon
uggh
ooo yummeh
i want to get flutes - but im not man enough to run straight thrus
Man up :cool:
Ok :D
Hole in one :P
:cool:
Can we play the meet you half way song?
We can play anything you want :P
Thats what she said
Out of idle curiosity mang, how much does centrelink give you every week/fortnight/whatever?
Thinking of quiting work going on the dole and then doing cashies?
I get $456 a fortnight.
As you can imagine, that's lots of fun... which is why I spend all day on the computer trawling job sites and harassing businesses for work. It just sucks that there's been eleventy billion people at each interview so far and they only want one :P
skins! isola!
i woke up with alarm blaring all i could think of was what you said night with the alarms going off lol
rest...
bitches..typical friday shit again
ha ha ha lol
i was like
zzzzzzz.....mothe......zzzzzzzz......f_ck.....zzzzzz
Wear a shorter skirt?
    • Sorry I didn’t explain myself properly, by free revving I meant if I just floor it, it gets to 7kish and will start to break up/not hit limiter properly, off boost I’ve driven the car until near on empty. I have a fuel pressure gauge mounted in the engine bay, holds fuel pressure consistently full tank or half tank even when revving, and no the pump sound doesn't change. all the fuel lines inside the tank are fairly new but will look into it, could that also be an issue with the lines outside the tank ?
    • Yeah maybe I got a bad batch that only lasted 6 years. Or conversely maybe I got a good batch that managed to last 6 years.    Either way I have sourced a set of OEM hub/bearing assemblies  so I keep hearing! Even from life long mechanics. Apparently this failure is unheard of…
    • I am trying to understand how that even happened to the hub... wtf
    • Hell, I'm sufficiently wary of the ZSS suspension arms, let alone something like a hub.
    • Got it back home and got started pulling the hub off and diagnose the issue. Axle was stuck after removing the 36mm nut so i used a 3 jaw puller to try and push it out and... eH5FXvJ8.mp4   spend the next few hours trying to remove the axle from the remaining hub as it was very much jammed in there when the spindle sheared off. resulting damage as below R53AIy6 - Imgur.mp4   Looks like the was already a stress fracturing in the spindle as can be seen with the darker cracked section My working theory is maybe when the pinion gear exploded last year the shock put through the hub was the initial crack. Then a few events later it finally let go. Just lucky it happened where it did and not 190km/h on the next sweeper or into the hairpin The bearing/hub assembly went in in 2019 and were non-genuine "ZSS" assemblies and no nails were harmed in the process. #BreakHubsNotNails
