fact: 99% of detomaso pantera's in oz are owned by gay blokes.
dunno why, but all the pantera owners i've met are all gay. what gives?
are you implying im only half the mang i think i am ?
like a mang but smaller cuter and furrier. awwwww.
you didn't want the disk back ?
hope not. i burnt it at work. had to it was that bad
mf/
lol if you're not going to keep it I'll get it back because it's a fun one to show to people. Like Poultrygeist. If you think ZS is bad you should see Poultrygeist!
i'll keep it. as a reminder to never watch it again.
now poultrygeist that sounds like my type of movie
mf/
Check out Bad Biology. Its teh awesomest.
as a first year mechanic i earnt $6.60 an hour, it sucked balls.
Im now qualified and pushing for a payrise so i can clear $1000 a week after tax. Will see how it goes
You're one of the lucky ones.. I know people who are qualified and earn/clear a little over half at that Merc and Holden
Do you have any idea how many "gay blokes" own imports/skylines...
They're so common in the car scene, seem to un-fitting? Lol at stero-type
Is that another Zombie movie? If so, I'll check it out as I'm always up for watching zombie movies even if they're terrible!
PS - Tas - Can you please price up some tyres for my herpes infested slut of a car? May I please have a price on 535s and 595s for comparison's sake? I may get the 53s to tide me over until I can grab some new rims. Or if you can think of something cheaper yet similar in lifespan/grip. Thanks :)
PS - Tas - Can you please price up some tyres for my herpes infested broad minded person of a car? May I please have a price on 535s and 595s for comparison's sake? I may get the 53s to tide me over until I can grab some new rims. Or if you can think of something cheaper yet similar in lifespan/grip. Thanks :)
your car gots the herpes ? and you wonder why i dont park next to you. Since we are on the subject of qoutes
Where's mine ?
MF/
mf/
Atm you're only manging at 50% of your manging potential mang.
595s are cheap as chips. Like <$200 a tyre in the sizes you would be after.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
